A55 Smoothing Plane
Nova DVR owners - lose shaft locking nut
Dave Paine
For the Nova DVR owners, posting in case this happens to you.
My machine is now 1 year old. I have not used in the last few months.
Today I was going to get back into turning and was going to remove the chuck so I went to lock the arbor and discovered the locking mechanism was VERY lose, as in I could pull this up, swivel etc. Scary. The last time I used the machine this did not move.
I disconnected the machine, removed the back panel and found that the lock nut had somehow, at some point in time come unscrewed.
The nut is 15/16 across flats. I re-tightened then installed the back panel. All is now back to normal operating condition.
I do not want to consider what may have happened if the nut had come off the shaft during operation.
Check your locking mechanism so this does not happen to you.
Re: Nova DVR owners - lose shaft locking nut
darrin hill
i actually think it happens to me all the time... if you turn the thing one way, it locks .. if you turn it the other way, it gets loose..
try turning it the other way and see if it unloosens..
Dale Jablonski
dale jablonski
This has happened to me multiple times and is very frustrating. In the past I had made the mistake sometimes of turning the machine on when the shaft was in the lock position and perhaps this contributed to the nut loosening. It hasn't happened recently Sooooooo tomorrow I think I'll take the back plate off and give it a preflight check. Good lathe though!
Carole Valentine
Are you guys talking about the knob that you turn for the indexing pin? Not sure I understand the problem.
walta
The index pin is not a shaft lock. I know because I bent mine beyond repair. Now to remove the chuck I but the knock out bar in the hand wheel and strike it with a hammer in the counter clock wise direction no need to restrain the chuck its own mass is enough.
Walta
Steven Antonucci
Problem is described in the manual
steven antonucci
I know exactly what you are describing, and I believe that it is advised in the manual.
If you rotate the locking pin (aka the index pin) clockwise to lock the shaft, you need to rotate it counter clockwise to unlock it. Some people continue to go clockwise every time they use it (or vice versa) and eventually they end up unscrewing it.
Work into the habit of always going one way to lock, and the other way to unlock and you will never have this problem. I am on year 12 with my Nova 3000, and it has never happened.
Steve
Jim Breeden
I believe I'm kinda confused here. It was myunderstanding the index pin is for indexing, not locking the shaft to remove a chuck- especially with a hammer! :b I have not had any problem removing a chuck by holding the hand wheel, and then unscrewing the chuck. Sometimes I do get the chuck on really tight, then I use the knockout bar in the handwheel and a strap wrench on the chuck.
Jim Sebring
This is a standard defect with the DVR because the factory chose to use a starlock washer under the nut.
I've fixed my DVR and the one my club has by using blue (removeable) Locktite to hold the nut in place. I also had the set screw that secures the index plate to the spindle loosten. I used blue Locktite on it also. If you use my technique be sure to carefully clean the threads before using the Locktite. I use acetone as a cleaning agent.
