Has anyone encountered problems with the tailstock or quill on the 46-460. Mine has been extremely difficult to operate for the past few months and today the quill came out of the backside of the tailstock. Went to the Delta site and found that both of these items are on backorder until Feb '12, makes me wonder if there is a problem and that they should be warranting these items.
I've never had a problem like that in about four years working with per-production and production versions of this lathe. I don't quite understand how the quill could come out the back unless the handle and shaft also came with it. Here's the lathe's exploded diagram: http://www.deltamachinery.com/downloads/manuals/lathes/46-460/EA023866.pdf Can you explain this a bit better?
Evidently over the period of time of having all the difficulty of using the machine in the manner it was operating, the cast iron housing elongated the hole where the quill attaches to the turning handle.....Someone indicated that there was a "d" ring but I do not see it in the IPB. I have put a rubber grommet on the quill just aft of the threaded portion and before the elongated hole in the housing and am going to try this this afternoon. If it works, then I will have a metal washer made to fit inside the housing just forward of where the handle attaches.
Andrew - Looking at the IPB, Part #52 is the quill. It is threaded on the inside. Part #58 attaches to the handle and screws into the quill, making it extend and retract as long as part #46 is sufficiently screwed into the groove in the quill to hold it from rotating. All that holds everything in the tailstock is the set screw on the handle and part #46 in the quill's groove. The hole at the rear of the tailstock is too small for the quill to come through, only the end of part #58 up to the machined ridge can. That's what the handle attaches to. There's no D ring anywhere. If part #58 (NOT the quill, but the "lead screw") is missing this ridge, nothing will work correctly.
HI Andrew, Looking at the schematic, there in not a dedicated groove and pin to keep the quill from rotating if the handle is loostened too much. I won't buy a lathe without that feature; in other words, if the handle is remove completely, the quill still should not rotate. Also, I always suggest that the quill be tightened when the lathe is being used. Leaving it loose will lead to premature wear of components.
Keith, my Stubby doesn't have one either. You don't need to tighten the handle all the way, just enough to stop the quill from rotating (unless you want to lock it).
When I had the tailstock from my 46-460 at the Delta Service Center this week, they told me that, in 2011, Black & Decker sold Delta to a company named Delta PEC who had also acquired Biesemeyer. Evidently, they have already moved to Anderson, SC. I hope the new company develops a decent service network.
I evidently allowed something to happen that shouldn't hae because the quill exited the back of the tailstock and today I made a poly washer the same size as the bore of the tailstock and the diameter of the quill and made it function...I am going to have a washer made so that I can hopefully resolve my situation.
Hi Walt, Looking at the diagram again, the lead screw has a shoulder near the rear , towards the handle. If that shoulder sheared off, the whole assembly could possibly slide out (or whatever the shoulder rides against broke). I would imagine the lead screw/quill assembly was loaded in from the factory and a circlip was installed to prevent it coming out, or a step was machined in the tailstock to accomplish the same thing.
If the Stubby doesn't present a problem with the quill rotating with the handle loose, there's not a problem. I've demo'd on several Jet lathes that the groove and the handle end had rounded over, making it very difficult use the tailstock without binding. Not good during a demo, and something I would avoid. I suppose a spring-loaded adjustment handle would solve the problem, keeping it seated in the groove even with the handle loostened.
I've not got a good understanding of what Andrew did to his to get the quill to come out the back. The hole in the tailstock casting is only large enough to let the end of the lead screw (part #58) stick out. It is much smaller in diameter than the quill, thus the machined ridge (not a clip on mine) stops it and the handwheel set screw holds the thing in place.
Neither Stubby nor Delta quills will rotate unless you unscrew the locking handle 4 or 5 turns. The groove in the quill is deep so you can have the handle loose but still keeping the quill from rotating. Your idea of a spring loaded pin would be good, but there'd have to be a way to remove it if you wanted to take the tailstock apart.
...quill when turning, especially when roughing green stock between centers. I'm frequently tightening the quill with the tailstock handwheel, and if locked it gives false info that the piece between centers is secure. I've never had a problem with quill movement when unlocked, especially with larger pieces on my Stubby(Studly!).
OK, I took my tailstock apart. The attached show how heavy the casting is and that the rear hole is too small for the quill to pass through, only the lead screw. They also show the machined ridge that stays inside the casting.
Re: Keith et all- I don't lock the tailstock......
Keith Tompkins
HI Jamie, You are correct on that point...a false sense of security. But watch, especially on a big unbalanced piece, you'll notice the quill wobbling slightly. Over time, it may distort the quill or the housing. I say "may" because I haven't seen it personally, but as a rule, anything left loose on a piece of machinery invites wear.
I evidently am stronger then I am aware, the quill broke through the rear of the tail stock after evidently wearing through the cast iron material which I think was a mfg error of some sort seeing as I am evidently the only person with a 46-460 which has had this happen. I turned on it today with my plastic washer installed just forward of the broken out area and seem to work fair. I am going to have a special washer machined by a friend to install in the place of the plastic one I made. Just knowing Delta will not stand behind their product after having been using it for over two years.
First off, in case you didn't read the box, the 46-460 comes with a FIVE year warranty for ALL parts. I don't work for them and don't get any remuneration of any kind from them at all. I'm just a satisfied customer. What you're saying happened to your tailstock is something I simply cannot understand after taking mine apart and seeing how thick the casting is at the rear. I'm not doubting you, but I also think you need to contact Delta customer service directly rather than putting this on a public forum. If you provide them some photos of your tailstock, I'm certain they'll be interested in making things right.
