Band saw help
dick hines
A friend has a delta 28-195 band saw and need a rip fence for it. The saw is not made anymore and he has no idea where to look for a fence.
Any ideas where he could find one/
Band saw help
dick hines
Re: Band saw help
Lewis Dodd
Delta! The make of the saw is not as important as the tablel some old table saw fences will work, Rockler sells tables with fences that fit over the existing table.
Re: Band saw help
I have a 14" Delta bandsaw that is about ten years old. I put a Kreg fence on it and I like it. I got the Micro adjuster and the point fence attachments and they work well.
Re: Band saw help
Harry Robinette
I had a Jet 14" and put a kreg fence on it there really nice fences for the money.
Re: Band saw help
I gave my fence away. The hardware to mount it got in the way with some of my homemade attachments. On the rare occasion where I need a fence I put a wooden one on. I have a homemade guide that I use for resawing. I like it better than a fence because I can compensate for drift very easily. I can't remember the last time I used a real fence. Oh yes I can. It was when I sawed slices off the end of a Tagua nut to make my own inlay's. I could have done that just as easily with a board clamped to the table.
MagnaFence from Carter Products
Chuck Bjorgen
Hey Dick -- I bought this fence from Carter when they offered a 25 percent off per-Christmas deal for about five days. Regular price is about $100. I also got the Carter Guide upgrade for my Jet 14 inch bandsaw which I installed yesterday. The fence works very well and it's easy to set up and remove. I did a drift test for a new blade, marked that on the table and found it easy to position the fence approximating the drift line. Obviously, the fence holds its position via magnets which are switched on and off.
Re: MagnaFence from Carter Products
Dick Coers
I've always been curious how that mag fence can have any repeatability. What happens if you want to move it back a 1/32"? There isn't anything that keeps it aligned is there?
Re: MagFence from Carter Products
Chuck Bjorgen
After installing a new blade, I did the drift test and marked a line on the table. It's pretty easy to use a tape measure to set the MagFence to the desired cut from that drift line. In my case, drift was not too great. Carter has a video on its site that demos the fence.
Re: Band saw help - this is on my to do list *LINK*
Stuart Johnson
The video is titled "Beating Bandsaw Table Drift" but it takes care of both a fence and drift. You do loose 3/4 inch of height but then how often do you use the full height?
Bandsaw fence / drift
