McNaughton Micro Center Saver
Tom
Anyone out there have experience with the McNaughton Micro Center Saver system with respect to coring small bowls in dry wood?
Is it only good for coring in green wood? Santa left a system for me and would like some advice/insights into using same?
Many thanks! Tom
Re: McNaughton Micro Center Saver
Dave in Alaska
I have the standard set for my big lathe and the Micro for my Vickmark 100 lathe. On the advice of Craft Supplies, I ended up with the Micro. I had totally trashed the set within two or three bowls. Sure, it was dry wood. But look at the knives and the flimsyness is pretty apparent. I can't recommend the Micro. Look to see if you can upgrade to the Mini at least.
Harry Robinette
Harry Robinette
I have the Large,Standard and mini sets and love them.I've heard some not so good comments about the Micro set. I'd try to upgrade to the Mini. Cored out 5 sets 6 and 7 ' 3 bowls each with the Mini.on 1hp lathe and had power left over.
Tom
Is it essential to only turn wet wood with either the micro or the mini?
Carole Valentine
No, you can turn either. By it's very nature the micro must be a thin blade with a thin kerf and therefore takes a very gentle touch. You cannot force the tool. You might try Steven D. Russell's pulse method which he describes on his site. If you have the micro-post you can use either the micro or small/mini blades. The small/minis are more substantial but create a correspondingly larger kerf.
Tom
Thanks to all for your responses/advice. Looks like I'll be ordering the mini blades!
Woodcentral is really great for getting help!!
Tx
Tom
Carole Valentine
It's best to have both anyway, unless you are strictly into doing miniatures. And even if you eventually go with a full size system on a big lathe, don't throw your micros away...they are great for those smallest little bowls in a set. Just be gentle with them. I used the micro just yesterday to take out the smallest bowl in a 7 1/2" set, then moved to the small blades for the rest. Have fun!
robo hippy
If your set is trashed in a few cores, you might be using them too hard. They are delicate, and will bend with use, just like the bigger blades can. You can easily bend them back into shape. You will need a circle template, one of the clear plastic ones, that you can lay the blades over, or even pencil lines on paper. The blades will tend to twist a bit, and you can torque them back till they lay flat on a work bench.
robo hippy
Tom
Many thanks again! All these tips are really appreciated!! My Mini set should be here in a few days!
Tom
