Re: Grinder Vac
Jesper, Denmark
Here is my set-up. Very similar idea, but with minor differences. Steel can vacuum cleaner with standard filter as delivered. The energy in the sparks from the grinder is long dissipated before it reaches the vacuum cleaner.
There is no more ginding dust around. The vaccum cleaner and the grinder are both wired to the same switch on the wall, so when you turn it on, both run at the same time. The switch was added after the pic.
The vac is a bit noisy, but not so much that I have bothered to add a sound enclosure - yet!
