I threw them both out. It's hard to hear the sound quality on my camera while filming. I had the mike too close to my mouth. Sounds like a garbled Darth Vader. I threw them both out. Bummer. I hate wasting time. I have a week off for the Holidays and about 3 weeks worth of work to fit in. Going to work on them again this morning. Oh well, the practice run went well and I know what I want to change.
I'm doing one on the Spindle Roughing gouge and the Hunter Hercules. Hope to do one on photography later in the week.
I've been working on a dust collection system for my grinder and finally putting in a more or less permanent collection system for the shop. I also put together a dust hood for my miter saw. It works great but I need heavier plastic for the front. I used a really cheap shower curtain. I going to buy a heavier one some time this week. The plastic is layered so I can move the saw any direction and still get pretty decent colletion. I am also going to come up with a better attachment to middle piece. Painters tape isn't all that classy.
Now I can get to work on the segmented project that I have to finish this week.
John, have you considered filming the video and then doing a voice over for the audio? Sometimes I think videos done this way are clearer in both the sound and explanations.
I'm in the process of building a bench-top spray booth during my non-teaching time between semesters right now. Exhaust port (commercial dryer vent) is already installed through the rim joist, and the blower/impeller mount is done. Building the booth and lining with stainless steel panels, making the lighting support, and building the replaceable filter unit are all that's left to do. Also trying to get some additional pieces finished for replenishment of successful gallery sales over the past two months.... ... I, too, hate wasting time!
Good luck with the videos - I'm also looking forward to the photography tutorial!
John, what are you using to collect grinding dust? I assume that it is NOT your regular dust collector! I have a dust port on my Dayton but it just seemed like too much of a hassle to hook up something that was fireproof.
Carol I'm going to use a really small Shop Vac. I doubt sparks could fly through almost 20 feet of pipe and cause a problem in my dust collector but I'm not willing to take a chance.
I'm going to do a spark test of some sort after I get it installed. I really don't think sparks will be a problem but want to set up some sort of worse case scenario with flammable stuff in the bottom of the vac and grinding steel that will produce way more sparks than my turning tools. Even so you can bet that I won't leave the shop without checking and emptying the vac. Since it's a wet dry vac I could just put some water in the bottom if I expect to do some really bad sparky grinding.
Any tips or thoughts anyone else has will be thoroughly absorbed and considered. Even though I think it's pretty remote it is a potential fire hazard.
I've been amassing equipment and techniques to improve woodturning demonstrations. Some of the audio stuff would likely do you some good with your videos.
Drop me an email and we can chat on the phone about it.
Carol, seethe other thread about the grinder collector above. My take is that there is not any great risk of sparks surviving a duct run, but I did not want to take any risk. The grinder is separated from general dust collection, so there is normally no flammable dust in the Vac. used for the grinder.
John, I have found that a short flexible hose on the dust outlet from the saw, directed at the outlet from the collector box improves the effiiency of the box. The blade is really turning the wrong way in the saw from an efficient pumping action, so there is a lot of "spray" of sawdust not picked up by the dustcollector port on the saw.
