Re: Broken Vacuum Guage?
Don Evans
Heather:
I have a large monitor so I was able to go over your setup easily with the pictures you posted. Your setup is appears perfect!
So we know it is pulling pressure due to the plate not falling off the drum, so only thing in question is how much pressure is there.
So:
1. Is it very difficult to pull the plate off the drum or impossible or next to impossible? I have to jerk darn hard to get mine off when it is pulling 27hg.
If answer to either one of these is yes, then we can pretty much conclude right there it is a bad gauge.
2. Did you use teflon tape on all the joints or dope from a can (usually these have a brush attached inside to the lid? One problem with dope is it can be pulled into places it should not be, like the pump in this case, although possible, maybe, I don't see it causing the gauge to stop working. I've never had any luck with dope on air pressure or vacuum systems, so having done that once, it's teflon tape for me for everything now.
You asked how to check the gauge. Take the hose off the bottom of the pipe that is holding the gauge and connect it directly to the gauge. If you have hose left over I would just cut a 6" piece off and connect gauge with that short pipe directly to the pump. Look in the connector end of the gauge first to make sure you don't see any obvious obstructions. The rubber stopper you mentioned concerns me slightly, I've never seen one on this type gauge but that doesn't really mean anything. When you take the stopper out can you see a screw in the hole, perhaps it is a "Zero adjustment" screw so you can callibrate it to zero with no pressure on it, I don't really know.
FYI the liquid filled gauges are used to stop vibrations from machinery from damaging the gauges and also makes reading them more accurate. Nothing worse it is area that trying to read a gauge that is bouncing from 20 to 28hg, hopefully an obvious joking here, hope you Powermatic never sees that much jumping up and down.
Don
