A customer asked me to both patch this 12 inch family heirloom bowl, while retaining it's patina, and make a duplicate bowl. The duplicate bowl is the easier part. Not sure of the original wood. One major, one minor crack as you can see. Cracks need gunk cleaned out before anything is done.
My question is what to use in the crack so I don't have to sand the area around it and destroy its look. The repair doesn't have to perfectly blend in with the surrounding wood, but it would be a bonus. I know superglue, with or without sawdust, is an option, but as I said, I can't sand the area.
I'm curious about steaming the bowl to help close the crack. Any problems in trying? What about putty or filler? Any that doesn't crack? That's water and vinegar proof? (I know vinwgar dissolves Elmer's white glue. Don't know about the other wood glues like Titebond.)
I don't know if Steam would work. It might close the crack but it would open up again. I would put Blue painters tape on the outside and then fill the crack with a thin epoxy in 2 or 3 steps. tilt it left fill, let it dry, tilt it right fill let it dry, then lay it flat and finish off. This should leave very little to clean up. A little careful work with a carving gouge should clean up any that runs over.
The closest thing to a magic glue I know of is Tech-Bond Molecular Bonding System. (wwwech-bond.net). This product will glue almost anything to anything else. Read some of the uses on the web page --
Lower tech - but seems to work for getting epoxy into small places is Abatron Liguid Wood Epoxy Wood Consolidant. This is a very thin slow setting high penetration epoxy used to consolidate and fix rotten wood on boats and other hard to penetrate places. I would clean the crack from both sides with dental picks and/or a high speed dental tool and carefully seal the bottom with tape (not blue masking tape as this stuff seeps right under it).
Either "fix" will be visible as a repair. Probably is time to retire it from active use as these fixes will fail over time and use.
2. Clean the crack with a sharp, thin knife point.
3. Coat the bowl, inside and out with 2 lb.cut shellac on 1" on either side of the crack.
4. When the shellac dries, carefully seal the inside surface of the bowl with tape like cloth or electrical tape.
5. Using a thin epoxy (sold as bar-top glaze), tint with a small drop of brown TransTint dye, then work into the crack from the outside surface by applying at center and drawing out to the tight ends with a small knife blade.
6. As the "downslope" portions of the crack are filled, working both ends to the middle, seal the outer surface of the crack with more tape in sections. The center/widest portion of the crack, in the bottom of the bowl, will be the last filled. Check every 10 minutes to make sure the center section is full and add more as may be needed.
7. Let the bowl sit for 2 days (Glazing epoxy is very slow cure)
8. Remove all of the tape and then remove the shellac with a rag and alcohol so as not to abrade the surface. The epoxy should be even with the edges of the crack without any sanding.
Steaming the bowl will do nothing as the crack will reopen and may even get worse with the heat and drying stress.
This has worked for me a several similar bowls, but make sure you tell the client that it will not be dishwasher safe.
CA glue isn't archival. Sure you could fill with it and some sawdust, but in a few years (5-10) it will likely open up again.
I would think a thin epoxy with some UV agents would be best. Talk to the companies posted and ask them about the above properties (especially archival).
