Renaissance Wax
Renaissance Wax
Jim Evans
Renaissance Wax
Jim Evans
I was looking at buying a jar of Renaissance wax until I saw that it was 6.5ML @ $22. This seems a bit high for 0.22 ounces of wax. Does anyone know how big the container is?
While I'm on this subject I found that Pennstateindustries sells an 8 ounce jar of microcrystline wax for $23. I know that 8 ounces is a cup, which is considerably larger than .00 ounces.
Has anyone used the PennState wax?
Re: Renaissance Wax
Re: Renaissance Wax *LINK*
HeatherAinAK
Here is a link with a photo of the 2 sizes of renaissance wax.
Renaissance wax
Re: Renaissance Wax
Carole Valentine
Some time ago I tried the Lee Valley MW. I liked the Ren. better. The cheaper ones appear to be much softer ...probably just cut with more solvent is my guess. Mine is 200 ml (7 oz) and was $23.99, but I see the KnifeCenter has the same sized tin on sale for $19.95. 65 ml for $15.95. I think there must have been a typo on your 6.5 ML...should have been 65. It will last you a LONG time. A little bit goes a long way.
http://www.knifecenter.com/item/CIOXRW2/
Re: Renaissance Wax
Jim Evans
Re: Renaissance Wax
Jim Evans
Yeah, I did get the weight wrong. it's 2.25 Oz or 6.5 ML. I am looking at Rockler and it's $21.99 for 6.5 ML
The Knife Center special is what I'm going to use.
Thanks Carol.
Re: Renaissance Wax
Re: Renaissance Wax
Tony Wheeler
I use Kiwi clear shoe polish and like it just as well and have both
Re: Renaissance Wax
Re: Renaissance Wax
jake Niedling
I have the large can of Renaissance wax and it lasts a long time and works well. I ran across this site about a week ago for another microcrystilline wax. I have not used it, but it is cheaper.
http://www.doctorswoodshop.com/OnlineStore.aspx
Re: Renaissance Wax
Re: Renaissance Wax
Bill Turpin in WNC mountains
I have the small can of Ren wax that we use for touch ups at shows. It has been used at seven shows over 2.5 years. There is a thumb sized depression missing. At this rate, it will last ten years! It is expensive, but I have gotten more than my money's worth. If you save a sale, what is ten cents worth of wax worth?
