punky maple
punky maple
punky maple
darrin hill
got a bit of spalted maple (from various sources) and i made a 2 inch pendant for my wife... it was punky and had a few holes in the surface after turning and sanding, so i thought i could put on a lot of lacquer and it would fill in the hole...
nope.. either that or i didnt put enough..
so a guy at the san antonio wood craft said to try this..
cut out a coke can bottom.
take pendant blank.. cover back of pendant blank with tape...
put blank in can bottom..
cover with 24 hour liquid epoxy.. let blank soak it up until it wont soak no mo..
let dry...
results are crystal clear resin that can be turned to pendant, sanded and buffed...
this a good method?
whats a good 24 hour 2 part epoxy?
Re: punky maple
Re: punky maple
Dick Coers
The epoxies I have used are not viscous enough to soak very deeply into wood. Are you trying to get stabilized wood, or wood that is encased in epoxy? Epoxy will not be crystal clear, and will probably yellow with age. The pen turner guys make blanks that are called "worthless wood". It's wood with worm holes, missing parts, etc., that are filled with tinted polyester resin. Then they turn it down and get a mix of wood and plastic. Polyester resin is the key here. Michaels and Hobby Lobby sell small containers of crystal clear casting resin. You can also use CA glue to stabilize small pieces of wood. Just don't use accelerator to get it to dry faster. Do give CA plenty of time to dry since a spinning blank of wood will send out a rooster tail of glue.
Re: punky maple
Re: punky maple
darrin hill
it was his way of making really stable wood..
i wasnt looking for a block of resin with wood floating in it.. Lol
Re: punky maple
Re: punky maple
darrin hill
for one thing i think the disks are rather light, and thought the resin would add some weight.
two...i could use ca, but i want it solid all the way through cause i never know how it's going to turn until i turn it..
Re: punky maple
Re: punky maple
Lewis Dodd
Darrin, I would ber interested in seeing a pic.
Re: punky maple
Re: punky maple
Ralph Lindberg
Over on the IAP (Pen Turners) forum there is a how too on converting a painting pressure tank from Harbor Freight into a pressure tank for taking block of junky wood and forcing the poly down into it. I've tried it and it does work
I also use Minwax Wood Stabilizer (carried by many Ace Hardware stores). Infact I have a really punky Maple bowl on the lathe right now that I used it on.
Re: punky maple
Re: punky maple
Darrin Use System 3 Mirror Coat. It is a 2 part epoxy from Woodcraft and becomes very viscous as it heats to cure. I've had it run completely though the end grain of a 2x4 that I thought I was using as a mold. I have used in on punky woods and it penetrates really well. I have not used it to do what I might call stabilize wood. It might work. All I now is it penetrates deeper than any other epoxy I 've tried.
Re: punky maple
Re: punky maple
Don Orr
You can also thin epoxy with either Acetone, Alcohol, or Lacquer thinner for better penetration.
Re: punky maple
Re: punky maple
darrin hill
im now curious to know if anything i put is going to make the maple darker...
Re: punky maple
Re: punky maple
Don Orr
My experience is that epoxy will dramatically darken punky maple. Not so much with sound wood.
