Fumed Oak Box
Fumed Oak Box
Fumed Oak Box
Don Orr
This was my exchange gift at the annual Onrust Holiday party. It was a big hit since it was made from scraps from the building of the ship. The body is white oak and the insert in the lid is is black locust. I wanted to make it a little darker than just an oil finish. I fumed it by placing it in a large plastic tote bin on a rack sitting above some household ammonia with the cover on. I left it overnight in a mildly warm shop. It got a lot darker than I wanted. I was looking for more of a Stickley mission reddish brown but got more of a dark grey instead. The medullary rays are not as prominent as I had hoped-kind of muddy. I sealed the inside with a light coat of shellac and the outside is Bush Oil.
Thoughts appreciated on the piece and the fuming.
Re: Fumed Oak Box
Re: Fumed Oak Box
Don Orr
Open view.
Re: Fumed Oak Box
Re: Fumed Oak Box
Don Evans
I like it the way it is, don't think it is too dark. On fuming (I've never done it) I wonder if the amount of "tannin" in the particular wood has an effect on this process. Oak is very high in tannin, infact I think it is the highest domestic wood in USA.
Don
Re: Fumed Oak Box
Re: Fumed Oak Box
Craig Daymon
Another example that shows household ammonia can do a good job of fuming with less risk.
Not that it would get any lighter, but the gray color you described is typical of pieces that have been fumed. Once the finish goes on it will go to a chocolate brown without any sign of the gray. (Least that's been my experience.)
Does this have finish on it now? The picture looks very mission brown to me.
Did you remember to let it air out, until the ammonia smell is gone, before applying a finish?
I think the box looks great. Nice job.
-Craig
Re: Fumed Oak Box
That's a wonderful antique brown .....
JamieDonaldson
...for white oak, and did you have the top of the box itself off when you fumed? How far into the wood does this process penetrate?
Re: Fumed Oak Box
Thanks Craig
Don Orr
There is an oil finish on it as you see it. And yes I let it air out til the smell was gone. At least to my unsensitive nose. :D
Re: Fumed Oak Box
Re: That's a wonderful antique brown .....
Don Orr
Thanks Jamie,
I did leave the top on the bin while fuming. I don't know how deep it goes-I did not do a test piece along with the box as I probably should have.
Re: Fumed Oak Box
Thanks Everyone !
Don Orr
By the way-the person who ended up with the box at the end of the exchange was the guy who cut all the wood for the ship with his Woodmizer. Very appropriate I thought.
Re: Fumed Oak Box
Don- I was asking if the top of the box........
JamieDonaldson
..itself was in place during the fuming, as it appears the box inside is as well colored as the exterior.
Re: Fumed Oak Box
Re: Don- I was asking if the top of the box.......
Craig Daymon
Jamie,
I think I know where you're headed with this. I've fumed a number of pieces, but haven't really checked the depth of penetration. If my guess is correct and you are contemplating fuming something where the inside looks unfumed and the outside is fumed (a box being a very good project for such an attempt), I'd consider a wall thickness of about 1/4" to be really effective. I've read that penetration is about 1/16" (a nice side effect of fuming being that it can be sanded to a limited degree afterwards), but I think the effect doesn't stop dead at that depth, it just tapers off.
IF this is what you are considering, White Oak would be better than Red as Red is substantially more porous and I would suspect more effected by fume penetration. American Chestnut, if you can find it (WITHOUT chopping it down), would be great as well. TONS of tannin in it.
I tried the two-tone effect with an American Chestnut bowl I turned several years ago by sitting the bowl top down on a piece of foam in the igloo cooler while fuming. I took a small square of MDF, drilled fine holes in it, put toothpicks in the holes, put the toothpick points against the bottom of the bowl and put a 5 pound weight on top of the MDF. If I did it again, I'd try a sheet of cling wrap between the bowl top and the foam to create a better seal.
-Craig
