A55 Smoothing Plane
Shellac mix
Shellac mix
Shellac mix
D. Hansen
what's the best (easiest) way to mix a 3 # cut for example of shellac flakes and alcohol? I think it is supposed to be measured by weight ratio but that is difficult to set up. I'm mixing just a quart at a time. (I know I should just buy some ready mix but I like to tinker). I just fill about a quarter of the bottle with flakes and then add alcohol about three times that volume.
Re: Shellac mix
Re: Shellac mix
Stuart Johnson
If your mixture is working for you and giving you the results then you have it right. There might be a reason for exact rations or cut but I sure don't know why.
Re: Shellac mix
Re: Shellac mix...from "Russ's Corner"
mjonesrdg
" I fill a graduated pint Mason jar to ¼ with flakes, then fill to just a bit over 1/2 full with denatured alcohol. This is roughly the equivalent of what the trade calls a 2-pound cut, or 2-pounds of shellac flakes in one gallon of denatured alcohol."
(Copied directly from "Russ's Corner" Re: WoodCentral, 'Articles')
Re: Shellac mix
Geez
D. Hansen
why didn't I think to look there . Thanks
Re: Shellac mix
I'd go with Shellac.net as the authority *LINK*
charlie belden
The "cut" is a weight of shellac, not volume, to a gallon of alcohol - according to what I thiink is THE Authority on Shellac - shellac.net. So a "3 pound cut" for a quart is a quart of denatured alcohol and 3/4 pound of shellac. But if you aren't starting with dewaxed shellac flakes, figure on 1/4 to 1/3rds of your mix to be a sludgy layer of wax.
shellac.net "pound cut chart"
Re: Shellac mix
Thanks Charlie!
Don Orr
That site's a keeper for sure!
Re: Shellac mix
Ditto. Great info!
