Wood burning tips
Wood burning tips
Wood burning tips
Don A. Davis
I just bought a pyrography system at an auction. It's a Nibsburner brand and came with two pens but no tips. So the question is can I make my own tips? For instance a paperclip fits perfectly into the holes in the pen. Could I bend something like this into the shape I want and use it as a tip? I have no experience with wood burning and am gutless with anything electrical. Thanks in advance for keeping me out of trouble!!
Re: Wood burning tips
Wouldn't use paper clips
Ray - Middletown, IN
You can get some nichrome wire and bend your own. Check Ebay or most of the manufacturers sell it also. I have a Colwood and they sell pieces of wire separately, go to your manufacturers website and check their tip section and see if they carry it.
Ray
Steven Antonucci
Ray is right
steven antonucci
You can buy more nichrome wire on eBay than you can ever use... for under $10.
Steve
Re: Wood burning tips *LINK*
I tear up old hair dryers, heaters, etc to get the Nichrome wire. You can also get it from craft supplies. More expensive than buying it on ebay but if your ordering something from craft supplies anyway it might be cost effective.
http://www.woodturnerscatalog.com/store/Carving___Pyrography___Pyrography___Create_a_tip_Pen___create_a_tip?Args=
Dick Hines
dick hines
Check www.sciencekit.com. They sell it in spools. I have been useing my first roll for 2-3 years and still have a lot left.
They have a large slection of sizes also.
McMaster-Carr is another source. *LINK*
Craig Daymon
They list wire diameters rather than gauge, but prices look pretty reasonable.
For reference, 18 gauge is 0.0403" in diameter and 22 gauge is 0.0253" in diameter.
McMaster-Carr Nickel-Chromium wire
Re: McMaster-Carr is another source.
Don A. Davis
Thank you guys. Now I'm much more comfortable trying to make my own tips. Ten feet of nichrome on its way. (Think that's enough!!!)
John in KS
What gauge of wire is used the most? Or should a person buy several different gauges???
Thanks in advance for any info you could provide!!!
John
Don A. Davis
John, I ordered 14 gauge. That's about 1/16 inch and it looks like what fits into the pen.
John in KS
Thanks Don, I will start with 14 ga then.
john
Terry Scott
You need to get some nichrome wire
Using a paper clip will burn out your hand piece if not the unit
Nichrome is a non-magnetic alloy of nickel, chromium, and often iron, usually used as a resistance wire. Patented in 1905, it is the oldest documented form of resistance heating alloy. A common alloy is 80% nickel and 20% chromium, by mass, but there are many others to accommodate various applications. It is silvery-grey in colour, is corrosion-resistant, and has a high melting point of about 1400
Terry Scott
If you have trouble finding it email me I buy in 20 foot rolls
Cheers
Rob Wallace
14 gauge nichrome is pretty hefty wire... *LINK*
Rob Wallace
....and you may want to start with 16, 18, or even 19 or 20 gauge. These are much easier to shape than 14 gauge will be.
For example - The three pieces of nichrome wire supplied with the "Create A Tip" woodburning pen (link below) are 18, 20, and 22 gauge, and will be much easier to form desired shapes than a 14 gauge wire will even allow. I would not recommend starting with 14 gauge!
Been there; done that - I have already been through the whole nichrome wire acquisition process - currently (pun intended) with a likely lifetime supply of different sizes.
Rob
Create a Pen  burner at Craft Supplies
Jim Evans
Re: 14 gauge nichrome is pretty hefty wire...
Jim Evans
Rob,
I agree 14 gauge is to big. I have found 16 gauge as the largest I like and 19-20 gauge the smallest. Anything smaller than 20 gauge is going to be very soft once it is heated.
Seems like 14 gauge would take a lot of power to use.
So far all I have been able to do is make charcoal with my battery charger unit. ;-)
John in KS
Thanks Rob and Jim for the additional info. I haven't order any yet, but plan to get some 16 and 18 ga to start out...
john
Re: 14 gauge nichrome is pretty hefty wire... *LINK*
Craig Daymon
An excellent recommendation Rob. I think I'd still buy from McMaster, but I'd base my purchase on what Craft Supplies is offering for tips as far as the gauge is concerned. That 14 gauge might be tough on your burner to keep hot.
A couple guys I knew back in PA built a great high powered burner from a microwave transformer (or maybe it was one they bought from a guy that builds them for foam slicers). I don't recall what gauge they were using, but it may have even been heavier than 14. It also threw up a 4" flame when they put it in contact with the wood.
I think the unit they had is linked below. I don't think Dan sells these anymore, but there are directions (for those that know what they are doing) there if you you want to make your own. This unit could handle 14 gauge., though you may have to build a custom pen to hold the wire as those sold for most burners would likely melt/catch fire.
-Craig
Dan's Workshop foam cutter from microwave parts
Rob Wallace
Another 'woodburning tip'..... *LINK*
Rob Wallace
Although this thread is evolving slightly from recommendations on nichrome wire size for burner tips, anyone experimenting with building their own burning pens and making their own tips might logically be interested in building a "high power" woodburning supply, popularly referred-to as a "wood vaporizer". These units can heat the wire so hot as to vaporize the wood in a burst of flame and smoke, and allows 'pyrocarving' of surface and other features in your pieces. Such a unit has been used by New Zealand woodturner Graeme Priddle to burn and carve many of his signature pieces.
I built one a while ago from a "manual" car battery charger (manufactured by Schumacher, and purchased at Theisen's Farm Store on sale for about $37.00). I used the instructions available on-line from the newsletter of the Silicon Valley Woodturners which is a well-written 'how to' on converting a car battery charger for use in woodburning applications - I have included the link below. Woodcentral 'regulars' John K. Jordan and Steve Antonucci contributed to the writing of this article.
Just a word of caution if using one of these high-power units with commercially-available pens - they are not generally designed for use with higher currents, and if you are not careful, you can ruin the tip quickly if excess current is put through the tip. Fortunately I have never ruined one of my pens (I use Detail Master pens, used with a Sabre IV burning unit for 'normal' woodburning) but I have heard reports of folks "frying" their pens with too much current, and ruining the tips by melting them, or destroying the wires with too much current. Caution is needed with these higher current power supply units!
My home-made wood burner/vaporizer unit works fine, but I usually limit my woodburning adventures to burning outdoors only due to smoke & fumes, which restricts me to doing burning on various pieces in non-winter (i.e. freakin' cold) seasons.
Have fun, but be careful with electricity and with very hot wires!
Rob Wallace
Priddle-style Wood Vaporizer Instructions
