Re: BAD INFLUENCE
Donna Banfield
I'm not a guy, but I can offer some help in spending your money :-)
If you want to pierce, you'll need a tool that can run at 350,000 to 400,00 rpm. Anything less, and the bit will want to follow the wood grain, making it hard to control the direction in which you want to do your cutting/piercing. I don't know if Foredom tools run that fast, as I've never used, nor looked into them.
The best tool for piercing right now is the NSK Presto, used and sold by Binh Pho and J. Paul Fennell, as well as other specialty wood carving stores.The Presto is oiless, the Powercrafter, another high speed carver, needs oil. There have been a few threads on other forums about the Powercrafter, and the downside of this tool.
High speed carvers need air to run them, so if you don't have a compressor, you'll need one. You'll also want a second regulator set up right where you're doing your carving/piercing. These tools are not cheap, (handpiece that holds the bit is about $360.00) and running them with too much psi can ruin a handpiece and the micromotor that's inside. You'll want to set your secondary regulator at around 38-40 psi.
Remember that these tools are not just for piercing; they can be used for texturing and carving with extreme detail....if that's something in which you're interested.
Hope this helps spend your money :-)
