A55 Smoothing Plane
"Cooling" a bandsaw blade?????
A friend tells me he lets his bandsaw run for a minute or two after he finishes cutting to cool the blade and tires. I have never heard of this and wonder if it serves any purpose. He claims it reduces the chance the blade will imprint the tires and take a "Set" form the shape of the wheels. Anybody got a thought on this?
Re: "Cooling" a bandsaw blade?????
A sharp blade should never get......
JamieDonaldson
..hot enough to cause any such problem? This is one of those theoretical discussion subjects that has some element of truth in concept for engineers, but not necessarily in application for average Joe User. Reminds me of my engineer Dad's practice of raising his car hood when parked, thus allowing the hot air to escape, thus reducing the heat damage to rubber hoses and belts. True in theory, but in practice it twice allowed someone to easily steal his battery, so which is worse? ;)
Re: A sharp blade should never get......
That was kinda my thinking.
About raising the car hood, would that expose the hoses to UV degradation? No good deed goes unpunished.
charlie belden
I've had a blade stick in a cut and the wheels kept turning. THAT stuck my blade to the "tires".
But normally blades don't get hot enough to soften the tires much. If you have melted rubber before, you know that it takes more than a few minutes for it to get hard again.
Could be this "heated tires" thing could be a justification for de-tensioning the blade so it doesn't "dent" the tires when they're hot.
bill Crommett
Something like the myth of lowering the tailgate to reduce wind resistance.
Walt Bennett
Walt Bennett
Don't know about heated tires, but I do know larger saws do not need to be de-tensioned. I forgot to set my reminder to re-tension just after getting my MM20 and destroyed a blade - since their 171" long and not cheap, I just quit releasing tension, but haven't noticed any blade or tire deformation in about seven years. The 1/2" blade on the saw now is about a year old, never had tension changed, and is running true (not all that sharp now, but not quite ready to replace either). I would imagine smaller band saws with correspondingly smaller wheels and blade widths might need this, but I don't believe larger ones do.
Keith Tompkins
Keith Tompkins
Walt, I've had my Delta 14" bandsaw since 1977. It's never been de-tentioned ever in that time with no issues. I've changed tires once for unrelated reasons during that time.
Walt Bennett
Walt Bennett
Then for certain the whole thing about removing tension after using your saw is another urban legend.
