I, too, really like the piece. Just started using dyes and would like to find out what kind of dyes were used and in which sequence. Also how much sanding was done after each application of color. Is is possible to get in contact with your Santa. Is he the one who lives at the north pole or somewhere else? .
I used the Chestnut dyes; unfortunately they are not available here in the US at present. They are a terrific product and I hope that someday they will be available here. I've not done much other work with dyes and stains but I understand that the "Trans Tint" products are also quite good. I followed the same protocol that Jimmy outlined in his recent Fine Woodworking spread on making a platter. The two articles are enough reason to pick up the issue if you don't already subscribe. Perhaps someone else could quote the issue number as I can't seem to find my copy right now.
I'm told that the alcohol based Chestnut dyes.....
JamieDonaldson
...are not very lightfast Joe, and since they're not available here in the US for testing I would stick with dyes and pigments that are known to be more permanent.
Re: I'm told that the alcohol based Chestnut dyes.
Bill Blasic
I use TransTint dyes as they are the most permanent dyes (metal acid) that I believe you can get in a size that most people can afford. Chris Pytlik also uses another metal acid dye but it only comes in sizes like quarts and costs in the hundreds of dollars and I don't remember the brand for sure. The small bottles of TransTint go a long way as you only need a few drops to make enough to dye a small to medium piece. I think that India ink is also very light fast and I got a bunch but as yet I haven't had time to try them.
Joe Herrmann
Jimmy showed us some pieces that had been dyed with the Chestnut products several years back and they still looked as fresh as the day he did them. I'd like to be able to get some of the Chestnut products to try a test for myself but they are not available. In the meantime, the Trans Tint dyes should work well from what I hear.
