My Blade Bows
Doug Reynolds in Seattle
I was cutting some wet cherry bowl blanks on my bandsaw over the weekend and had a problem with the blade bowing making the sides more or less round. The blanks averaged 4-8 inches thick and 10 inches in diameter. I was using a 1/2 inch skip tooth blade on a MiniMax 20. Tension was per the blade manufacterer's instructions regarding flutter test then add a partial turn. Upper guides were set about one inch above the highest point of the wood. This is a common problem for me and thick wet wood.
What am I doing wrong? Is the blade too big, dull or, just the wrong choice for this application?
TIA, Doug
