On 'turning air'
BarbS
Okay, I need further input from you experts. On FB this morning, Melvyn Firmager advised another turner: "for me it is down to gouge tool control - not 'rubbing' the bevel (as to do so when turning 'air' causes tool bounce), offering the tools to the wood not pushing against it, good body movement, relaxing and breathing."
I thanked him for posting his advice, but I'm a bit lost. If not trying to stay on the bevel when turning air, do I just offer the sharpened edge softly, directly on to the surface at as high a speed as I can? I've only tried this twice, and both times my gouge gave me so much bouncing and tear out (chunks-out) when trying to utilize the bevel, that I know I'm doing it wrongly.
HI Barb, Here's my method..I turn LOTS of air. First, I take a levelling cut, pulling from the center out to the edges. The tool is an Ellsworth style grind, the lower edge is doing the cutting. No bevel rubbing, more of a scraping cut, just to level things out. The tool is presented at almost 90 degrees, no catches that way. Then, with bevel rubbing, I cut from center to the outside edge to clean up the cut. For the final cuts, I cut towards the center, bevel rubbing, just as you would turn a conventional bowl. I've found when cutting air, flute straight up helps prevent bouncing..it's one of the few times I cut flute up.
