Turning-The ways
Turning-The ways
Turning-The ways
Lewis Dodd
What do you use to lubricate your ways?
Re: Turning-The ways
Lubricate may not be the best term....
JamieDonaldson
.. for assuring easy movement of the banjo or tailstock on the ways. I use WD-40 and gray Scotch Brite pads to reduce/remove rust and stains, and this results in allowing the ease of movement you are seeking.
bill Crommett
If I am peeling turnips or rutabagas on the lathe, I use Canola spray. If I am turning wet wood I use WD-40. Otherwise because my shop is very dry, I ignore the problem until I get some gum build-up.
Steven Antonucci
nuthin'-don't want the banjo 2 move when I lock it
Johnson's Paste Wax.
Harry Robinette
harry robinette
I started using PG2000 ( I think thats the number ) I've used it for about 2 months now and really like it.
Everything holds with no slipping at all and everything slides when it's released .To me this stuff works wonders.You can't tell it's on the ways after it's dry so nothing sticks to it. I been using it on my General bed lathe and my Vega bowl lathe both.
I use Renaissance wax to coat my ways. I usually turn kiln dried wood though.
If I am turning wet wood, I usually use paste wax (Johnson's).
WD-40 and properly tuned tailstock
I've used both WD-40 and Johnson's paste wax. WD-40 is simply faster to apply. When I'm turning thinks like Oak I will spray the bed down several times during the day. When turning other woods I spray it down and then wipe it off. That will usually last for several turning sessions before I need to do it again.
I don't have the problem on my Powermatic of tailstock slipping. With a few of my older lathes if I lubed the bed the tailstock would slip. There are 3 solutions. One is to flatten the tailstock so it mates accurately with the bed. That's a chore and I'll describe it if someone really wants to know.
The second and 3rd method usually work. You need to tighten the bolt on the bottom that adjusts the tension or lever angle. This will give you maximum leverage. And you need to make or buy a larger locking plate for the bottom. The ones that come on many lathes are simply too small. There just isn't enough purchase area to properly grip. I make my own but there are some rectangular ones on sale somewhere on the net. I'll have to look and see if I bookmarked that site.
Rob Wallace
Monster lathe Mini T-nuts.... *LINK*
Rob Wallace
I think this might be the site John is thinking about.
I bought a set for my Jet Mini, and it does make a big difference.
See the link below...
Happy Holidays,
Rob
Monster Lathe Mini T-nuts
Bill Turpin in WNC mountains
Most cast iron will warp slightly over a period of years. This is just enough to cause binding between the bed, tailstock, and banjo. When new and/or when binding occurs, take a flat file, lay it across a flat area (both sides of bed) and take a few strokes. Any shiny spots will show the warp. This will take out poor finishing in the Chinese machine shops. This will clean up spilled finishes, light rust, and CA drops. Be sure that the file is across at least two points of contact. You want to flatten the surface, not change its shape. Use this same technique on the rubbing points on the bottom of banjo and tailstock.
Rob Wallace
Cleaning and sealing the lathe bed... *LINK*
Rob Wallace
At least twice a year, (sometimes more often when needed) I first polish the ways with a fine rubberized abrasive block (available from Klingspor), then thoroughly clean the ways with mineral spirits, and finally wipe them down completely with dry towels. I then seal the polished, clean (oil/wax-free) surfaces (including the undersides of the banjo and tailstock) with Bostick Top Cote (see link below), which is a dry, friction-reducing metal sealer made for woodworking applications. (I also use this product on my table saw, jointer, and band saw tables.)
In my experience, Top-Cote is far better than paste wax, and not nearly as messy as WD-40 (and it does not attract and hold wood dust like liquid lubricants do) - I have used both in the past. For the past 10 years or more, I have used the Top Cote product on all three of my lathes, and am very happy with how this cleaning and sealing combination works. When I turn wet oak, wet cherry or other acidic, high-tannin woods, I apply a liberal amount of Top Cote (which dries within 30 seconds) to the ways under the blank just before turning them, and do not experience staining or pitting of the metal surface.
I can say with certainty that I would not return to using WD-40 or paste wax.
Works well for me.
Rob
Bostik Top Cote
There has been a really great set of articles on scraping for flattening metal lathe beds in the last 3 or issues of home shop machinist. I've been devouring them because I have been fascinated with this concept ever since I read about many years ago. It is much more accurate than trying to file or sand a tailstock to match the lathe bed.
John: can you send us a link when you get home. My method seems to be accurate enough for wood lathes. Also, everybody already owns a file. A $5.oo Nicholson file is all you need. A combination of many of these ideas will keep you spinning with a smile on your face.
Bill Sent my self a not home so I'll remember to look up the articles. They are way too deep and detailed for most of us but interesting non the less. It's kind of like asking a guy what time it is and he tells you how to build a watch.
steve worcester
If you want them slippery, clean them, sand them with about 400 grit and use T-9 Boshield. Bowling alley wax works well too, but doesn't last as long.
Don McLeod
I use a hard wax to lubricate the ways and keep the Scotchbrite handy when turning green wood. I have an older model General 260 and have always had a problem with tail stock slippage. I had a larger nut made which helped a lot but after reading the replys, I'm going to have a new one made with a bigger footprint and see if it helps. I always seem to leave this forum with a new piece of information or a refreshing of the gray cells. John, I look forward to the links on scraping the lathe ways.
John Jordan
The Generals were known for that-evryone made larger plates for the tailstock. It took General about 15 years to implement that change. :D There's no reason for anything to slip on a well lubricated, smooth modern lathe. If it takes more than a couple of fingers to move the rest or tailstock, and moderate pressure to lock, something is wrong.
I like and use WD40, which has no drawbacks to me, but I wouldn't argue with someone that uses something else, or does it another way, so long as it moves EASILY.
A smooth/polished/lubed or waxed toolrest, and easy to move tool rest base will improve one's turning, with no practice. :D Every time I turn, I use a little steel wool, or sandpaper, and polish the rest and spray the bed, and the cam in the tool rest base, and a little on the spindle threads, and wipe it off with a rag or paper towel. I can't do a demo until these things have been done to the demo lathe as well.
John
Srcaping bed ways *LINK*
There has been a 5 part series in The Home Shop Machinist magazine about scraping. Scraping for the Home Shop by Michael Ward. It is fascinating. This method is used to flatten the bed and mating surfaces within 10,000" accuracy. It is a long hard to read article but very informative. Someday I will probably try it.
He even explains how to make the tools which of course I found very interesting. I am most interested not in scraping the bed itself but in mating the tailstock to the bed more accurately. The higher quality lathes have been flattened to the point that tailstock slipping is not a problem. Still I want to give this a shot some day.
I don't know if you can get back issues of these articles. I don't think it's available online although I didn't do an extensive search of the website
http://www.homeshopmachinist.net/home
Re: Srcaping bed ways
To cover the high points of the article. You put a thin marking chemical on the base of the tailstock. Rub the tailstock back and forth on the bed. This rubs off some of the marking liquid. These are the high spots. You scrape, using a special tool, the high spots and do the test again. You do this many times until the high spots cover most if not all of the base of the tailstock.
OK most of us don't have metal scrapers and probably won't build one. However with a thin file that flexes or even very careful application of sandpaper you should be able to flatten it better than it is.
You could also make it worse of course so I would take this action as a last resort. Try the other methods I mentioned above before trying to flatten the base. This would probably only be necessary on less expensive lathes or old and badly worn lathes. ON older lathes the bed could be warped or worn so I would check the tailstock in several areas to try and narrow the problem down.
Walt Bennett
Walt Bennett
Lewis, you've found one of the many 'issues' that different turners have very different opinions on. Next question you might ask is if a chuck should be used in expanding or contracting mode - you'll get the same kind of response!
