Embers
Embers
Phil Stivers
Embers
Phil Stivers
I was forwarded an email from one of our club's members (San Deigo Woodturners) telling a chilling story. Some details are sketchy; more details as they are known...
Russ (I don't think he's a member of this group) was turning a bowl in the shop when a hot ember "escaped". He thought he had put it out and taken care of it, only to awake a few hours later to the house in flames. He and his wife escaped only with their car. They are now staying with relatives.
Our love and prayer go out to him. I'll be exploring possible ideas for help....
Re: Embers
Re: Embers
That's terrible. MY prayers go out to them. I'm really curios as to how he got a hot ember while turning? I've gotten them from sharpening and certainly while burning the edges with a torch. Obviously this situation brings to light the constant need to be wary in your shop, both while your there and when you leave.
Re: Embers
My sympathies as well.
Mike Foster
I have been through the same thing. Fortunately we did not lose the whole house, and were able to live in the half that was undamaged for the winter before rebuilding. It is one of the low points of my life that I do not care to relive. So our thoughts go out to them.
Like John, I am a bit confused about embers being generated by turning. I know the wood sometimes comes off hot from the friction of turning, but there is never smoke unless it is something I am intentionally doing. Really curious about more details on that.
Re: Embers
Dale Jablonski
Re: My sympathies as well.
dale jablonski
I have experienced smoking when using a wire during buring manuevers and I had hot/smoking sawdust when using a forstner bit that burned my skin when I touched it. This caused me to shut down operations and perform mop up/cold trail of the sawdust. I found that some of the sawdust could have been warm enough to perhaps kindle a fire if left. Though rare, it only takes once.
Re: Embers
Another good reason to maintain a .....
JamieDonaldson
..."spiffy" clean shop, especially at the end of a working/turning day. A sad lesson to learn the hard way. :(
Re: Embers
Jim Evans
Jim Evans
Me thinks you are/were a wildland firefighter - "mop up/cold trail "
Re: Embers
Harry Robinette
Re: Embers
harry robinette
my sympathies also
Almost lost my shop in Clovis NM. 1991 Hot sparks from a grinder into shavings from a planer.My daughter seen smoke when she came home 20 min after I left shop,no damage luckily.
Let us know whats happening we all have to stick together.
Re: Embers
Re: Another good reason to maintain a .....
Carol Reed
Indeed! Truly a compelling argument for cleaning up the shop at the each session. I, too, had a near disaster several years ago. Left a cross that needed repair too close to a heater. Went in for lunch. Returned 30 minutes later to shop full of smoke. What a mess, but I still had a whole shop to clean up as opposed to rebuild. Even salvaged the cross. Now I am pretty anal about keeping the shop clean, not pristine and not always everything in its place, but floor and horizontal surfaces service relatively clean. Lot of money invested out there, not to mention my heart which would be crushed if I foolishly did something stupid enough to burn it down.
The fellow in Phil's post is a member of my turning club, though I don't know him. Phil, one of my best friends, promised more info as it became available.
Re: Embers
I thought my Forstner bits were bad....
I have a set of really CHEAP Chinese bits and they are bad and get hot, but not that hot. Are you spinning them too fast?
A friend's family had a fire from a wood stove before he was born. They Hammered the lesson into him so well that when he has a fire in the wood stove he goes back to the shop every night before bed to sweep around the stove again and check on it. Can't go to bed until he does.
Re: Embers
Smoke detectors
Bill Howatt
And it is necessary to make sure the "sweepings" are disposed of properly preferably outside the shop.
My lathe is in a separate room off the flat-work part of my basement shop and each room has its own smoke-detector. If the shop is in a separate building a wireless or wired smoke detector that provides an alarm in the house is a good idea.
Bill
Re: Embers
Very Sad Story
Don Orr
I hope evrything works out in the end.
Re: Embers
Phil Stivers
Re: Embers
Phil Stivers
UPDATE - I received permission to distribute the following. It gives better detail into the incident and an update into the current status...
To: San Diego Woodturners/ La Jolla Playreaders
Some startling news, but all people are ok.
Thursday night, the Duff’s woke up to fire outside their bedroom in Russ’s woodturning area. Earlier in the evening while on his lathe, Russ spotted a spark and stomped it, thinking it was out. At 11:30 pm Russ and Eloise woke up, alerted to three foot flames visible through the sliding glass door. They bolted out of bed, called 911, and then got their cars out of the garage.
The fire department responded with 7 trucks and a helicopter to contain the fire and successfully kept it from spreading to any other Mount La Jolla unit. However, the entire back of the Duff house is destroyed. The front of the house is intact but suffered severe smoke and water damage. Their computers and records were saved, fortunately. Also, Eloise’s drawings and Russ’s turnings are smokey, but repairable.
They are safe and living with a brother who is close by. Eloise’s daughter is on her way back and Russ’s son Eric, who lives here, is a resource. They have plenty of help to house and clothe and feed them at the moment.
Re: Embers
Re: Embers
Stuart Johnson
Phil, do you have any idea what caused the ember?
Re: Embers
Re: Embers
K. Freitas
Russ is in our club in San Diego. Several of us have been asking ourselves the same questions and a few possible issues have come to light.
Two different people said they had lights with regular incandescent bulbs near their lathes which most of us do. They both said they had saw dust inside the hood of the lights which get very hot and smoke started coming out. I have the same type of light but not too long ago I switched to a energy saving bulb which stays much cooler. One of our guys said he dumped the smoking saw dust out and tried to stomp it out but took it one step further by using a shovel to take it outside and put water on it.
I don't really know if that was the cause of this fire but it is one place to look and make sure the saw dust is not too hot. I've also had workers who were staining some doors and they left the rags in a pile on our grass. About 3 hours later, I noticed smoke coming up and as soon as I picked them up to lay them out flat, they burst into flames. So it can happen when you least expect it.
Be Safe out there!
