quick question about the Jet 1236
GaryG in MD
I've used this lathe for many years without a hand wheel.
Now I have a need for one.
Can someone tell me the bolt thread size necessary to match up with the interior threading of the spindle on the back side? I assume it's left handed...
The info is not in the instruction manual.
Where might I get such a bolt?
Thanks, Gary
Re: quick question about the Jet 1236
Alan Zenreich
Alan Zenreich
If I recall correctly it is a very non-standard 1/2 - 12 LH thread (most 1/2" bolts are 13 tpi)
It might be easier and cheaper to order a handwheel directly from Jet. I think it was pretty inexpensive.
Tom
Gary, had a Jet 1236. I ordered a handwheel from Jet. Problem was that it had no hole in the center for using the punch rod to remove a drive center. I had to remove the handwheel to do so. Handwheel ended up in the "not used" bin! I have since sold the lathe. The newer models come with a handwheel but it does not fit older models according to the company. Hope this helps!
Thanks Alan and Tom...
GaryG in MD
I've gotten along just fine for many years without one, but I started turning pens, and it would be handy for that.
I see that someone with the same problem used a spindle tap to create one to put on the right side of the spindle. That wouldn't work for most applications, but it will solve my problem because the pen mandrel goes into the spindle with a Morse taper. So you can have both at the same time. Another good use for my rarely-used spindle tap!
Thanks for your comments and info. ...Gary
