After all of your good advise I am convinced that the Dremel is not the ideal tool for piercing. So I am going to purchase a air powered handpiece. The nsk is out of my price range so I am considering the Power Crafter, the Power Carver, and the Turbo 2. These three have similar pricing. I am leaning toward the Powercarver, but I would like to know if any of you have any experience with these, or any others that perhaps I should consider. Your comments are very much appreciated.
If I had to do it again, I would buy the NSK Presto high speed handpiece, rather than the Powercrafter I have now. Oil-less versus oil-requiring is a big difference - some have also hinted that the NSK has somewhat higher torque than the Powercrafter as well.
The NSK Presto has a good track record among woodturners and carvers. There also have been recent reports that customer service with Powercrafter units is, (trying to be polite) less than desirable. Craft Supplies and Treeline dropped carrying the Powercrafter and now sell the NSK, as does Binh Pho, J. Paul Fennell, and several woodcarving specialty on-line vendors. Should tell you something.
Are you interested in buying a lightly-used Powercrafter unit?
I agree the NSK is the way to go. Before I bought the NSK I used and still use a dental system that I got from Kurt Hertzog when he went to the NSK. While not quite as expensive as the NSK the dental unit must use oil and the hand piece is at an angle rather than straight like the NSK. I know you can put together a dental handpiece system for less than $300 off EBAY and I know that there is someone out there that sells the dental systems but cannot find the link at the moment.
There is one place in Canada that I know about that sells the true dentist drill and accessories to go with it, like hose connectors etc. It is actually two guys and 2 sites I'll list but they actually work together on this.
It is also my understanding that it is ILLEGAL for anyone in USA to own one of these unless you are a licensed dentist.
I have concluded that is why the dentist that started all this way back when had to design the straight cigar shaped units that are sold to woodworkers.
Check this site and search it a little and you will find the drills:
www.onegoodturn.ca
or
www.langercraftworks.com
First one is Brian McEvoys and second one is Gord Langer.
I'm also surprised to hear there was a 90 deg drill made for dentist that used oil. Must be really old one.
No one really stated to true problem with the oilled units, it is because these drills will suddenly spit oil out onto you work. If you are going to use an oil/varnish finish I don't see this being big problem but if using another type finish then it becomes a big problem. I have the powercrafter also and run into this spitting problem now and then. If I was going to replace it right now I would go with the NSK (I cannot say in writing that I would go to canada and get an illegal one right!) I really don't think this would be a problem for anyone unless they set up a dentist practice without being a real dentist.
Don, are you sure about dental drills and dentists only? If so, there are a lot of people in violation of regulations. I think this may be an "urban myth". As far as spitting oil, the only way this would happen is to use too much oil to lubricate. I have not had any problem with oil on my piercings.
I've had no problem with oil and my dentist gave me a drill as he was fascinated with the pierced turning I gave him. All the hand pieces that my dentist uses on my teeth have the cutter coming out at 90°. It is my understanding that the ones like the NSK are used by technicians as in making teeth etc.? The ones pictured on the sites mentioned are like the one I use. Be sure that the hand piece you get is one that turns at 300K or over.
I'm as sure as I can be without reading the statue itself. But all the things that I have ran into on this subject support what I said. All of these events took place more that 10 years ago.
I also obtained one of these drills, how I will not say, but prior to that I tried to purchase one via same place that any dentist gets one and was told I could not purchase one. In another event I tried to purchase parts from a company within USA and was told the same thing, I could not get parts for it because I wasn't a dentist.
Do you know of anyone in USA that sells them? Only one's I've found are in Canada, why is that?
I don't think it is a myth, I believe it was created to insure that not just anyone could call themselves a dentist but like lot of law it is a dumb attempt in the wrong direction.
I have only passed along what I have been told by companies that sell this stuff I see no reason for them to jerk me around.
Hope the DEA isn't reading all this, that is the Dentist Enforcement not Drug Enforement.
Your comment on over oiling interest me. I'm always willing to learn so tell me how you oil yours? I admit I use, probably, oil that is too heavy. It is the oil made for air tools like grinders and brad nailers and I only put in one drop.
A much lighter oil not made from pertroleum would be better maybe like mineral oil.
Things like hair clippers come with a little bottle of oil which is perfectly clear so I suspect that is mineral oil. I have one of those and think I will try it.
When I do oil it, I drop one drop in the air inlet and then run it before actually using it but I will still end up with that spit sometimes which seems to happen when it is under more load than normal.
Don, a couple of things. First, I use a lubricant made for dental drills which you can get in a spray can or a small bottle. I think you may be asking for trouble if you use another type of lubricant. Second, you can purchase dental drills on ebay, Amazon among others as well as burrs. I have had my handpiece serviced by a company specialized in doing so and have bought parts for it. At no time was I asked if I was a dentist.
Well Hal, I'm very happy to learn that I was given incorrect information!
But how about sharing the information. Who is the company and any contact information you can provide for the folks that sold you parts? I still have one that needs attention.
I use singer sewing machine oil and put in a drop every hour or so. I am so used to getting stuff from ebay that that is where I generally start but I'm pretty sure that one of the prominent dental suppliers on ebay is in California.
Don, just so you don't think you were dreaming.... I looked into purchasing a dental light from a surplus company a few years back and there was some sort of statement about being allowed to only ship to licensed dentists or suppliers. I don't remember the exact wording but whatever it was I wasn't eligible. I also don't have any idea if was policy or law but you can now find them online.
Thanks for posting Stuart I knew I wasn't dreaming but I was beginning to wonder about the old memory. Lot of water goes under that bridge since 1973 when I started doing the turning thing.
