Short sweet video *LINK*
http://www.youtube.com/watch?v=k7gQv6SrUUA
Re: Short sweet video *LINK*
Mike Stafford
Glenn is a remarkably skilled and prolific turner. I had the chance to watch him for two weeks and he shows the wood no mercy.
Glenn was turning bowls on a big Vicmarc lathe and he had the wood screaming every day. The amount of wood he removed in each roughing pass was amazing and then the finish he could achieve directly off the tool required very little sanding.
Although known as a production bowl turner Glenn can turn anything and turn it well.
He is a very nice guy as well.
Lyle Jamieson
How many of you can do Richards ride the bevel on the top inside a goblet pulling out from the bottom to the edge with bevel support?? At first I thought it was you doing it John.
#4Re: Short sweet video
I haven't taken the time to learn that yet. I did play with it one day and it apparently takes practice. I'm not willing to try it on a box I need yet. Maybe I'll put some scrap on the lathe and learn it this Christmas.
Lyle Jamieson
Its harder then a skew to master. It is as complex as it gets for tool control. For production turners it is fast and sweet. I did it enough to say I can do it but it would take a long time to master it. I was still holding my breath and white knuckling it. I did not take the time. I have done hundreds of goblets but my shapes needed my boring bar and laser so I never got back to Richards cut.
Mike Stafford
I actually learned back hollowing from the man himself, Richard Raffan. I don't routinely do it on dry wood but I like it more and more for roughing green wood blanks.
One of the first things I learned is that I had to have the correct grind on my gouge. Not just any grind will do the job well. It is actually easier with the correct grind.
Scary to learn by yourself!!!!
Lyle Jamieson
I learned from Richard too, but I guess Im a slow learner, and I have not taken the practice time to master it. I have to think way too much, its not routine yet.
#8Re: Short sweet video
Dick Wilson
Yes, it is a sweet video. I can see that it will be a must purchase for our wood guild. Yep, I would say that anyone who owns a fork lift, a kiln the size of a small house trailer, and a dump truck trailer is definately a production turner.
#9Oh no, you have to think! I'm screwed
#10That opening scene is mindbending...
GaryG in MD
I had to watch it five times to even begin to grasp what he did so quickly. ...Gary
I am like you Lyle...
steven antonucci
I can do it well... sometimes. And other times, not as well
I use a hook tool to cut end grain, and never looked back.
Steve
Keith Tompkins
Lyle, I think if you look very closely at the clip, the bevel is rubbing initially, but then the tool shaft itself, NOT the bevel entirely, is supporting the cut. Look at the rim as the cut progresses, and how the tool is resting against it.
I'm not an expert on this cut by any means, but if I try to rely entirely on bevel contact, I fare poorly. By supporting the cut with the shaft, thereby keeping the cutting edge where I want it, I gain far more control.
When turning complex spindle forms, I do the same thing..the tool may be far over the tool rest, but the shaft is braced against a feature of the turning, for example a bead, while the cutting edge is cutting a fillet where no bevel support is initially possible.
You wanna see fast.... *LINK*
Mike Stafford
Watch this short video of Glenn turning a top.....
21 second top
Lyle Jamieson
Good explanation Keith, Yes, the leverage from the tool supported against the rim of the goblet is a huge part of the control. If I understood Richard correctly the bevel is also supporting the cut all the time, too. So a twist of the wrist is necessary as you leverage against the rim and pull the cut. Knowing it, and doing it, are two different things. :-))
It's like dunking a basketball, Lyle
steven antonucci
Just jump high and throw the ball down...easy.
S
#16Jeeez, another thing I can't do.
Although when I was in gymnastics we used to dunk the ball using a mini trampoline.
I almost dunked once in a game
steven antonucci
but I didn't.
We also tried having a guy get down on all fours and dunk off of his back once, but you have to be pretty drunk to be that guy, and he has to be pretty big to withstand the guy using him as a trampoline. You only get one chance at it, because no matter how drunk the guy is, it hurts so much that it snaps them back to sober...
(I was neither person, but I was there when it happened and had to call a timeout because I couldn't breathe from laughing so hard...)
S
