Really bad chatter?
Really bad chatter?
Really bad chatter?
Tony - Memphis
Let me begin by confessing that I am not much of a turner! I am trying to turn some sppons for Christmas presents. These are around 12-14" long in tiger maple. I am not turning them very small in diameter - around 1/2" at teh smallest point. After I turn the handles, I shape the spoon end by hand and scoop out the spoon by hand. Anyway, I am getting terrible chatter. I turned the speed down to 1200 or so. I am using a Jet mini. I have good tools and they are pretty sharp (Tormek). I tried a roughing gouge and a spindle gouge. Teh rougher did better, but not great. Any basic tips? Any help would be appreciated. I don't recall having this much trouble turning other things before, but maybe I just forgot!?!
Thanks,
Tony
Re: Really bad chatter?
Dick Coers
That kind of length and diameter are a combination for chatter. Very light cuts, and use your hand on the back side of the handle section to help dampen the vibration. I forgot what species you are using, but harder woods will vibrate less than softer species.
Jim Rutten
Also, start from the tailstock side and work towards the headstock.
BarbS
BarbS
Is your tail stock set too tightly? Too much pressure will make long spindles chatter as you thin them down.
All of the above and you might try turning the middle first and working towards each end. It's excessive pressure on the bevel, along with flex in the wood that causes this. You do need to use the bevel to control the cut but most turners are now referring to gliding the bevel rather than rubbing the bevel. the idea is to not push on the wood any harder than absolutely necessary to make the cut. Then to counter this small pressure use your hand on the opposite side to dampen that pressure.
Once you get the chatter use even lighter pressure with a very sharp tool and change the angle of cutting edge so you ride on the high points of the previous chatter marks. then cut these down.
Worse case scenaria, just do the best you can and sand them out.
Thanks all!
Tony - Memphis
Looking back at my post...I'm not much of a speller/typer either!
Thanks much for the help. I'll kepp after it.
Tony
Mike Peace
Re: Thanks all!
Mike Peace
You might also put the spoon portion between chuck jaws instead of turning with a drive center.
