John Lucas a question
Dennis Taylor
On the hand out for making the hand mirrors, you indicated a 3/8 dowel in both the waste block and also in the square waste block, are the dowels intended to hold the two together or are they also glued together, just no glue on the dowel? Set up and ready, but wasn't sure, figure they must be glued also? thanks...Dennis
Re: John Lucas a question
No the dowel isn't glue in. It' just purely an alignment tool. Since there will be some residual glue left on both wasteblocks you have to true the surface before you use them again. It's much easier without the dowel in place. I get many miles out of my wasteblocks before they get too small to use. The faceplate wasteblock will let you know when it's too short by taking nicks out of your scraper when you hit the screws. :) I hate it when that happens. Sometimes being too cheap costs you when you have to grind out those nicks.
By the way a Thompson gouge will stay sharp 4 times longer after hitting the screws. :) Just kidding. A thompson gouge will take a nice chuck out of your chuck without damage to the gouge. Been there done that.
Dennis Taylor
Figured it was another glue block, so the dowel is for alignment purpose only. I have a Talon chuck, you kind of indicated the chuck is the easier mounting method, which steps get eliminated with the chuck. Also I have a few of the Thompson gouges myself, lucky enough to have him as a member of the local turning club, luck of the draw! I would prefer to use the chuck only due to I think it will make it simpler, unless you have reason for the glue block, i.e. alignment? Dennis
Dennis The chuck only works if you have 4" jaws that expand into the mirror opening. I still use the 3" square block glued on the center of the mirror but I grip it with the chuck jaws and can do away with gluing that block to the faceplate block.
When I don't use the chuck I have to trim the 3" square block whose diagonals are slightly larger than 4" down to a snug fit in the mirror opening. That's how the mirror blank is aligned when reversing. When I use the chuck I simply expand the jaws into the 4" opening.
