I would like to know whether anyone of you with this lathe has installed an on-off switch at the tail stock end.
The power switch of this lathe turns off the lathe but it does not turn off the power to the VFD. This lathe is running on 220V so a simple SPST switch will not work. A Unisaw switch or will work but it costs a lot.
It works on my Nova and if I use it the motor resets to off. I assume that is because if there is a power outage and you forget to turn the lathe off it will not crank back up on its own when power is restored.
the powermatic 3520 has a remote switch but it is a simple single throw single pole switch. It does not shut off the VFD. You don't need to for general safety of shutting off the lathe. You only need to turn off the drive from the VFD.
You can buy a double-pole, double-throw (DPDT) switch at Lowe's or a local electrical supplier that will switch the main power to the lathe. When installed, it looks like an ordinary light switch. It is not a big thing in a metal box with a lever, and it doesn't cost a lot.
As you know, the switch will have 4 terminals. However, another switch that has 4 terminals and looks identical is called a 4-way switch, and will not work. This switch is used for turning a light On or OFF at multiple locations. If you get the wrong switch, the power will stay ON all the time. Flipping the switch will have no effect.
That's what I used on my old lathe which didn't have a VFD. I put it there so I could turn off the lathe in an emergency without having to reach past the spinning blank which likely would be in some sort of distress.
I don't bother turning off my General VFD unless lightning is forecast and then I unplug it. The VFD does stay slightly powered but I'm not a person who really likes startup surges on electronic equipment so I just let it idle - opinions vary on this though.
If your lathe is variable speed: the VFD generates a low voltage signal that goes to the speed pot, reverse and stop button. You can put a SPST switch in series with the stop switch on the headstock. You could add several if desired.
Here's a relatively simple way to install an Emergency Off switch on a PM 3520 or Jet 1642.
Break the circuit going to the main On-Off switch, the one with the big red knob. That is, cut one of the wires going to the switch. Attach a length of lamp cord or other suitable wire to the resulting two ends of the wire you cut. Use small wire nuts.
To the end of the lamp cord, which may be several feet long, attach an ordinary light switch. And that's it, except for routing the wire, mounting the switch, etc.
With this setup, the light switch must be ON all the time for the lathe to run. However, turning the switch OFF will stop the lathe in all circumstances. Otherwise, the main switch with the big red knob will operate normally.
If you pull the big red knob to ON and leave it there, the emergency switch will then operate as an ON -OFF and you can then use it to start and stop the lathe as you wish.
To protect the electronics, remove the main power from the lathe before you begin cutting wires and so forth. The voltage on the wires going to the switch is very low, like 13 V, and the current it carries is next to nothing. There is no shock hazard involved here.
Steve Schlumpf has a nice write-up on this if you're looking for just a remote on-off. His mod will not turn the VFD off. Since I installed mine, I have not used the Big Red Button. Ever. Never.
Also, I have my lathe feed run through a DPDT switch and turn it off every time I leave the shop. Just like unplugging, but easier.
I built a cutoff switch a few years ago. PM sells remote switches but I got the supplies and built one instead. I did not price the PM switch but it may have been cheaper to by the PM switch.
If you want to build one. Go to amy good electrical supply store and get a switch. Then on the way home stop by one of the big box stores. You will need a shore piece of cable and a "OUT DOOR" box and lid. A good magnet is good to have too. glue it to the back of the box so you can hang the switch where you want.
For the PM and expect for the Jett also you remove the blue wire off the off/on swt. Hook the new white wire to where to blue wire came from. Then hook the blue wire to the new black wire. Then hook up the new switch. Fo
For the remote swt. to work the main swt. must be on.
It is a much easier task than I thought. I took the switch out and I saw the blue wire. There is also a hole at the bottom of the head stock so connecting a wire to the blue wire is easy. I am going to connect the blue wire to a SPST switch mounted at the tail stock end. This way, I will keep the red switch on all the time and just use the remote switch for turning the lathe on and off. The red switch will still work as long as the remote switch is on.
I remoted my General 26020 On/Off switches so I could place a shop-built remote control box wherever I wanted it. I also put the speed control in the same box so I could readily see what the speed setting was before I turned the lathe on.
I didn't want the lathe to be set to top speed on the pot from the last job and now I've put something larger or less balanced on the lathe and its going to want to go fast. Granted, VFD machines ramp the speed up so you probably have time to adjust the speed or turn it off if this happens, but it is something to be aware of when you are turning it on from a remote position.
PS: If anybody is thinking of remoting their General On/Off buttons be careful (at least with the older models, don't know about the latest) - the switches have the full 240V on them. I made a circuit to avoid running this voltage to my box.
