Chatter Work - An easier(?) method *LINK*
Craig Daymon
I was flipping through an old Craft Supplies catalog and saw the Henry Taylor Elf Decorating/Texturing tool. I read the description and thought it would be pretty easy to make one myself. (I have several carving burrs and plenty of rare earth magnets in assorted sizes already.) Doing a quick search on-line for more info, I found out I'm not the first to make my own. Anyone using this tool or already made their own?
Henry Taylor has 4 great videos on using the tool on their site (link below) and Highland Woodworking has the plans for making your own, as well as a $29.99 kit of the needed parts.
http://www.highlandwoodworking.com/mini-texturing-tool-kit.aspx
Rather than buying bearings and a router collet (or the kit), I'm going to make my own bearing from UHMW plastic, which I already have. I'll turn the UHMW to fit my tubing (copper, Lowes didn't have any brass tubing) and drill the appropriate size hole for the shank of my carving cutters. Ideally, I'll drill the hole so the shank extends by about a quarter inch and then part off my "bearing" with about 1/32" between the end of the "bearing" and the bottom of the hole. That way in use the shank won't be in direct contact with the magnets.
-Craig
P.S. Even if you create chatter work using a traditional chatter tool, the videos are worth checking out. The 3rd one shows some very interesting patterns using multiple cutters.
Elf Decorating Tool Description and Videos
