Another teapot l made out of Pear. l tried to replicate a porcelain effect by bleaching but it did not reach the white l was looking for. l made the second photo black and white and it comes closer to the effect l was looking for.
Mike I find it takes a lot of coats to really lighten wood. That being said some woods simply won't go light or do strange things. Osage orange for example turned barnwood gray when I bleached it a bunch of times.
Walnut will get quite light. Wenge only bleaches the lighter brown, the dark browns stay the same color. Box Elder bleaches pretty white but the brown and red streaks don't bleach at all or very little.
Run a test. I haven't tried to bleach something perfectly white so it should be interesting to see. If I get time I'll try some samples before I come down for Christmas.
Mike, you did not say what kind of bleach you used. The two-part bleach (with peroxide) is pretty effective. As John said you may want to repeat the process for maximum whitening.
Very nice clean, smooth teapot, Mike, which Bradford pear will give you. For all the good things about Bradford pear though taking bleach is not one of them. I've seen the effect you want somewhere, and as soon as my feeble neurons fire I'll let you know.
Lovely pot Mike. I love all of your pots. If you want a porcelain effect, try something besides pear...some maples and clear holly are best. I use Kleenstrip...several applications over a wet piece and then a final application of Part B alone (or is it A? Can't remember without looking!) And I have found that the finish is very important...must be absolutely clear and non-yellowing and a matte one will look more like porcelain. I use the Krylon Crystal Clear Matte or Velvit Oil Aqua Shield Satin and knock it back just a bit with fine synthetic pad. A light hand buff with museum wax will give it just a tiny bit of soft glow without a shine. No power buffing!
Mike I don't follow the instructions. I mix part A and B together and then apply it. I let the piece dry and then apply another coat. I can get about a days worth of coats out of one mixed batch even though they say it won't work. I have also never used a neutralizer.
The instructions say a neutralizer should be used before any finish. I have done lots of pieces and put several different types of finishes on. I've never had a problem.
I bleach regularly and have never neutralized and have never had a problem with a finish. What I use says to mix part A &B together and have never had to do more than three coats to get the effect I'm looking for. I do let it dry for a day or two and give it a light sanding.
