Veritas - Innovation in Tools
ca pen finish
ca pen finish
ca pen finish
Dennis Taylor
Turned a couple of acrylic pens, and sanded and had a smooth finish on it. applied ca to the pen, small amounts of medium ca with very low rpm, applied several coats in same manner, spraying hardener after each coat. Wet sanded, finish looks o.k. but seems to be small bubbles in finish under the top layers, can sand out. Not sure if the bubbles are due to temp in shop being cold or the use of the spray. I turned a few awhile back, warmer outside, but didn't use the spray. Any idea where my issue might be? thanks...I followed the guidelines now as well as in the past with Barry Gross Acrylic dvd, didn't have issue until now, and it is in both pens tonight. thanks again. Dennis
Re: ca pen finish
Re: ca pen finish
Dick Coers
Why CA on top of acrylic? I sand to 12000 with micromesh, then plastic polish. Can't get any slicker than that.
Re: ca pen finish
Alan Zenreich
Re: ca pen finish
Alan Zenreich
Agreed, no need for any finish on an acrylic blank. I MicroMesh to 12k, then buff with a wheel from Barry Gross with blue polish compound.
Re: ca pen finish
Re: ca pen finish
Wayne Kuhn
I agree with the others, no need for ca finish on acrylics. Actually I don't believe in ca finish on wood. Wood by it's nature will gain a beautiful patina with use, Its what wood does. I have a friendly debate with a fellow club member concerning this.
When a wooden pen is finished properly it will shine with the best of ca finishes, with use oils from your hand will maintain this shine along with the patina. I say, if you want a plastic finish, turn the pen out of plastic.
BTW the the bubbles are from the foaming of the ca with the accelerator.
Try ca without the accelerator-if you must.
Wayne
Re: ca pen finish
Re: ca pen finish
Dennis Taylor
I used the process that Barry uses in his Acrylic Turning dvd, at least the finish process, and I did figure the bubbles were from the accelerator, I won't use it any more, and not the ca, just try the finish from the sanding, I did sand with the micro mesh, and looked great, but he indicated the ca for a finish, don't use on wood myself, but for the acrylic I figure it would be fine, I think the acrylic is the same material as the ca glue hardened anyway. Any how I will only sand and buff, no ca on acrylic. thanks.
