Sea Urchin Ornments
Stuart Johnson
What is the best way to fit the top and finial to the sea urchin? How are they glued on? Why did I wait until Dec. 6th to start Christmas presents?
Sea Urchin Ornments
Stuart Johnson
Re: Sea Urchin Ornments
Mike Brazeau
I have used 5 minute epoxy but have also used a technique Eugen Schlaak uses - put a short length of 1/4" dowel between the finial and the icycle or turn a dowel as part of the icycle tennon.
Mike Stafford
I cannot give a definitive answer to question one as there is more than one way to skin a cat or hang an urchin ornament.
My dear departed friend Ed Moore used to connect the top finial with the bottom icicle by turning a tenon above the section of the icicle which abutted the bottom of the urchin shell that was long enough and thin enough to pass through the hole in the top of the urchin and a hole in the top finial. The icicle was glued to the urchin shell and the finial. The finial was also glued to the urchin shell. That way the ornament and the urchin shell itself was hanging/supported by the screw eye that was attached to the long tenon of the icicle. Hope that makes sense.... See parts picture below. Turning this configuration requires that the turner create some collets with which to grasp the thin shaft that will protrude through the urchin shell and allow the top section of the icicle which is glued to the underside of the top of the shell to be held. See collet picture below.
Answer to question 2: Procrastination perhaps.....
mjonesrdg
Because Dec. 6, is the perfect day to get started! Me, I'm such a procrastinator...
Bill Howatt
I make a top and bottom which may or may not include an icicle. My bottoms with icicles are 2 pieces the larger diameter bottom with a 1/4" hole to receive the tenon from the icicle.
The shells as you know aren't totally regular so I don't bother trying to make a tight-fitting tenon on the caps for either the top or bottom holes.
I use a Dremel-like tool with a stone to grind off the the knobs that keep the cap from sitting reasonably flat on the shell. These are the "sputnik" shells not the real thin and delecate ones. There are reports that the fine shell dust is very nasty to breathe so use proper protection.
The parts are assembled onto the shells with 5 minute epoxy. Good gap filling and gives a bit of time for getting the best alignment.
Bill
Nick Tuzzolino
Stuart:
See woodturnerscatalog.com (Craft Supply)..Search for sea urchins, they have instructions for just what you are looking for. I am going to start turning mine for Christmas tomorrow. Or maybe the day after. Right!
D. Hansen
I grind the top and bottom relatively flat on a sander then hot melt glue two finials that have been sized individually to cover the holes. Dec 6th is just about right don't see anything wrong with that.
Re: Sea Urchin Ornments *LINK*
Juergen
Go to the link and below the Sea Urchin Ornament DVD picture select the line drawing PDF.
Sea Urchin Ornament Line Drawing
Carol Reed, Pahrump, NV
Thanks for the link!
Have you used these DVD's and if so, what is your review?
Re: Sea Urchin Ornments - Thanks
Stuart Johnson
Thanks everyone for the pointers. Now I need to get them done.
Canadian Source of Shells
Bill Howatt
Tropitek in Vancouver. They apparently ship to the US as well.
Juergen
I haven't seen the DVD. However, I've seen Kip do a demo where he makes 10 items in about 1 hour 15 minutes. There is no wasted time, everything is thought out and as simple as it can be made.
What I likes about this design is one can make the finail in one piece and slide the urchin on without the bother of making a top, a botton and then having to fiddle with the lenght of the dowel to join them. I think this is a very elegant and simple solution and will saves a lot of time.
