A55 Smoothing Plane
Chatter work
Chatter work
Chatter work
D. Hansen
Anyone know of a good resource for chatter work? I have a CD that shows someone doing it but the instruction is lacking. Speed of lathe, orientation of the tool, length of the vibrating tip and what are the effects of each, etc is what I am after. Since I have the tool it would be nice to know what to do with it. Not having too much luck on my own. TIA
Re: Chatter work
Re: Chatter work
Bill Turpin in WNC mountains
Bonnie Klein is very good at it.
Re: Chatter work
Re: Chatter work
Everything you do changes the chatter. Start with the tool held at an angle about 7 oclock on the piece. You want the tip tilted down. After that it's just a matter of playing.
The surface speed of the wood changes as you move from outside to center so that changes the chatter. The hardness of the wood changes the chatter as well as the stiffness of the tool. Extend it further or retract it, hang it over the tool rest further, litterally everything you do changes the pattern.
What I do is take some hard wood and make a dowel out of it. Chatter work only works on end grain. Anyway I just play, turn it away and play again. When you get something you like part it off. Now you have a chatter work button you can insert into other turnings.
After a while you'll get the hang of it and feel more comfortable about doing it on the original piece.
It's also fun to rub wax into the grooves of the chatter work. you can color the top of the chatter work with colored pens.
I have instructions for making a chatter tool on our club website. Look under the tips pages.
Re: Chatter work
Steven Antonucci
The thing that nobody says about chatter is...
steven antonucci
that you will get much better results if you hone the edge of the cutter and then pull a fine burr! It is a small scraper.
Steve
Re: Chatter work
John: the address for your article?
Re: Chatter work
Thanks!
Jorge
This thread ios timely, I am making tops for a school fair on saturday and I don't have a shatter tool yet. Out to find the pieces, Thanks
Re: Chatter work
Steven Antonucci
I use a broken sawblade with a fingernail shape
steven antonucci
In a pinch, you can just grab it with vise grips. No reason to go nuts with a dedicated tool.
Steve
Re: Chatter work
sorry about that.  *LINK*
http://www.cumberlandwoodturners.com/htm/tips.htm
Re: Chatter work
Re: I have many shatter tools! No instruction need
Re: Chatter work
Steven Antonucci
I break them myself
steven antonucci
In general, a chatter tool is nothing more than a flat piece of good steel held firmly, but allowed to vibrate to create the chatter.
If you take an old, dull jigsaw blade, it is probably too long to be useful unless previously broken unintentionally. A few seconds on the grinder gets rid of the teeth. The holding mechanism does not need to be fancy or elaborate... you only chatter for a second or two.
I have made handles in the past because it makes people feel better about it, but the handle is purely ornamental.
S
Re: Chatter work
Re: Chatter work
Ralph Lindberg
Yup, she just did a demo at the local club, including that subject.
It as kind of a fun demo, as it was a large variety of short subjects
Re: Chatter work
I've made chatter tool blades from.........
JamieDonaldson
..a variety of materials such as metal banding strips that are used for shipping purposes. The stiffness and widths create different patterns, as well as using a variety of lathe speeds.
Re: Chatter work
Good idea! Thanks
Re: Chatter work
Re: Chatter work
Doug Turner
I was recently at a woodturning school at Ishikawa prefecture, Japan. They have a dvd of a "national treasure woodturner" using about 15 different hook tool type chatter tools (I tried unsucessfully to get a copy). Each chatter tool gives a different effect. Some chatter work I saw was about 14" in daimeter on a huge cover bowl. Other exteremes were a small antique box with chatter work groves greater than 1/8" deep. Pretty amazing turning.
BTW the turning school takes 3 years to graduate as a journeyman woodturner. The first thing you learn is blacksmithing to make your own set of tools, then how to sharpen on waterstones, how to use the various tools correctly, how to duplicate each of the classical cups, bowls, plates and platters uniformly to within .1mm, how to apply a finish base and a urushi natural lacquer finish that is impervious to liquids up to 600 degrees centigrade.
Re: Chatter work
Re: Chatter work
Philip Morris
There are several YouTube videos that demonstrate the technique along with its variations.
Also, Sorby has a good video demonstrating the use of their chattertool. CraftSupplies has a link to the Sorby video on their webpage for the Sorby Chattertool.
Re: Chatter work
Steven Antonucci
Chatter vs. spiked wheel
steven antonucci
Chatter tool has the vibrating cutter. The tools like the decorating elf have spiral wheels that resemble knurling wheels used by machinists. They do different things.
I am not sure the Sorby tool you mention isn't the knurled cutter?
Steve
