Mark 8 Micro Center Saver System
Tom
I am considering purchasing the above system for use on my midi lathe. Does anyone out there have experience with this system, especially on a small lathe? I don't make big bowls and think this system would be useful. I have a Turncrafter Commander Midi Lathe from Penn State.
Many thanks for any advice!
Re: Mark 8 Micro Center Saver System
robo hippy
The micro system is made for mini lathes. I think the biggest you can core is 10 inch diameter. It would be mostly for decorative pieces where you want to save every scrap. Not for production work. All of the other systems have cutters that are about 3/8 inch wide. The micro system is 1/4 inch wide. A 3/4 hp motor would have no trouble, and a 1/2 hp motor would probably handle it easily as well. I tend to be very rough on my tools, and bent some of the micro blades when I used them, but they are easy to bend back in shape. Take it easy and let it cut at its own pace.
robo hippy
Tom
Many thanks for the info!! Since I'm not in the production business, it might just work for me! Appreciate you taking the time to respond! Tom
