Time-consuming icicles
BarbS
BarbS
These little things took much too long to make and finish for what they're worth!
But they're cute. Maybe I'll spend the year cutting these out of scrap and tossing them in a box, then sell them in groups for next year.
Maple or Sycamore, 3" to 5" long
Re: Time-consuming icicles
Carol Reed, Pahrump, NV
Nice, Barb.
And great finial practice!
Those are really nice. I don't know how fast your lathe will run, but you should be doing these at or near max speed. And, you know how to get to Carnegie Hall don't you? Practice, practice, practice. Time on the tool really counts. Now that you have the idea, crank them out and you will get better and better and faster and faster.
Don Leydens
Don Leydens
You are absolutely right! Today I hope to finish the last of about 75 icicle tops and bottoms for ornament globes (Christmas presents) and I won't miss them when I'm done. I will say though, my speed, quality and design work are much better for it. Lots of chances to develop your own style of finial too. Easy to say now, but my turning skills for small work in general have improved because of making all these pieces.
BarbS
BarbS
Yes, I understand the repetition thing; it's valuable. The long one with six drops, for instance, was my sixth, and the only one completed as I wished it to be. The others are all shortened because of breakage and getting over-zealous, trying to improve my 'time.' I have it figured now, to cut one in about 20 minutes, but including the raw wood prep, then the oiling, waiting for cure, and the Beal buffing in stages, the time involved doesn't seem efficient for the price these might go for. If I do a bunch of them as toss-offs all year, and not while under the gun to produce Christmas items, I may feel different about them. I also did Christmas angels for my Etsy shop, and for the time involved, I think they are the more efficient item. Just something to consider.
Mike Rubes, Apex, NC
Hi Barb,
Those angels are GREAT! I love the simplicity of them. My mom puts out lots of angels at Christmas, so I think I will try to spin her a few of these. I really like that design.
Thanks for the pic!
Mike
More ideas than time in Apex, NC!!!
A question
Hi Barb,
How did you attach the wings? And did you turn the wings 3 times, or drill the top/bottom hole for the wing effect? Please feel free to email me if you don't want to post "trade secrets"!! :)
Thanks!
I think I've even got some holly laying around.....
Mike
Alreading lining up the angel list in Apex, NC!!!
BarbS
Re: A question
BarbS
Mike, no trade secrets. I could not find the old article I had seen these described in, so I had to 'wing it.' I turned a tenon on a 1" square piece to reverse and turn the dished wings, then mounted the dished-in surface over a lined jamb-chuck to turn the tenon down to a 1/4" peg to inset into the back of the angel. When I do more I will make the peg 3/8", as the smaller one is prone to breakage too easily. It also helps to barely plane flat the back of the angel around the hole, so glue seepage can additionally bond the wings to the back. And, I used a large Forstner bit to drill out the wing holes after shaping the disc. A little dicey, but any breakage/tear out can be corrected with files, as you are cutting away the outer edge of the drilled circle anyway. I've always admired all the great ideas Nick Cook has given us over the years. I'm pretty sure this was his original idea, published for AAW. If anyone knows differently, please let me know.
BarbS
BarbS
Don, 75's an Odd number! ;-) I hope we get to see a photo of all those ornaments hanging somewhere, when you've completed them.
Nice Angels. I do the wings one of two ways I guess it depends on how I feel that day. One is to hollow out the bowl portion and then sort or rough out the back and turn a tenon for my chuck, or possible 3/4" to fit my Nova tailstock with the center removed. Then I have a scrap block that is roughly the bowl shape that I used with double stick tape to put the wing on. I use the tenon and tailstock to center it. I really only do this when I want decoration on the back side of the wing.
The other method is to glue the blank to a wasteblock. Then turn the bowl and most of the backside, I sand these and apply a thin layer of finish. Then I finish turning the backside down to a 3/8" tenon. I also tried 1/4" tenons but since it's side grain they are too fragile. I use epoxy and let a little bit bleed out of the hole to make a stronger bond because the tenon is a little weak in my opinion.
Mike Stafford
Re: A question *LINK*
Mike Stafford
Mike here is a link to Nick Cook's article on turning Christmas angels.
Nick Cook Holiday Angel
BarbS
Thanks, Mike!
Keith Tompkins
Keith Tompkins
Hi Barb, Here's how I would turn these...mount the blank in a chuck, no tailstock. Start on the end furthest from the chuck, working towards the chuck; the mass will support the cut. With good technique, sharp tools, almost no sanding ...220 grit max. to start. Many turners use the gouge with the flute facing straight up, bevel rubbing. Don't be afraid to roll the tool in the direction of the cut to turn the beads, it's faster, and the cut is cleaner. Time to turn each, with a bit of practice should be under two minutes. The key is not just practice, but practice with good technique, no wasted movements. I hope this helps.
BarbS
BarbS
Hi Keith- I'm trying to turn these icicles about 6" long, so a 7" blank would have to extend from the chuck. I had been doing it between centers, with a tail stock firm but not too tight. I discovered pretty quickly I was doing it backward in trying to cut the widest top end at the tail stock instead of leaving that mass at the headstock end. I will try your method, without a tailstock, or maybe with a small cup center around that end and no pressure. It's going to take practicing Dozens, though, for me to get down around five minutes with these! Thanks.
Barb I do what Keith does. A chuck helps stabilize the blank. I usually start with the tailstock in place to rough it out and then remove the tailstock. I use finger pressure on the other side opposite the bevel to reduce chatter. You absolutely must be light on the bevel and have very sharp tools.
I haven't timed myself on something like that but I turn my mirror handles in 15 minutes and they are much longer and have more details to fiddle over.
BarbS
BarbS
Thanks, John. I know it isn't a 'race,' but utilizing some of these techniques you guys are sharing should improve the efficiency of making them. I'll be working on it.
There are wax sticks you can use for finish on something like this. I can not remember the name, but maybe somebody will chime in. You finish the piece, sanded smooth and rub the wax on with the lathe running and polish with a paper towel. Be very careful rubbing it in and its better not to use a rag in case the turning takes it away from you and flogs you senseless. Not much danger to you, but it could snap a turning this small the Icicles, not the angles.
BarbS
BarbS
Thanks, everybody. Barry, I think you mean HUT wax or PPP... I had some in a drawer and forgot about it. I'll use it next. I went back out to the shop after lunch to practice what Keith and John offered me. Much improved. I made these four, with light sanding and wax added, in only an hour. They're small, 2-1/2" to 3", but I'll offer them as add-on package baubles for a gift recipient to use later as a light pull or ceiling fan pull. Thanks for all the advice. These are fun to make.
The are called HUT abrasive waxes
WoW Barb!
Don Orr
You sure pick up these tips fast! The first ones were nice and well done , but now you are sure getting the hang of it. You did a great job on the Angels too.
BarbS
Thank you, Don!
Brad Vietje
Nice Improvement in efficiency, Barb!
Re: A question
Hi Mike,
Thanks for the link, that is very helpful.
Mike
Keith Tompkins
Re: WoW Barb!
Keith Tompkins
Hey Don....wow, she sure does!!!
