Veritas - Innovation in Tools
Powermatic 3520 Measurements
John Kaner
Hi! I want to make a steady rest for my friend.
I need the measurement(s) from the bed to the middle of the spindle and the gap between the ways. Forgot, how thick are the ways?
It'll be the standard circular with 3 arms and a captured block at bottom to secure it.
Have the plywood and wheels (Salvation Army) and hardware.
Thank you for your help.
Re: Powermatic 3520 Measurements
Doc Green
PM 3520B: Distance from ways to center of spindle: 10.25"
Distance between ways: 2.5" Thickness of ways: 9/16"
Longest dimension of clamping block ... 3.625" will work fine.
~Doc
Thank You
John Kaner
Doc,
Appreciate that. He'll be happy. I love your book and have learned some neat stuff.
Re: Thank You
Doc Green
Thanks, John. The dimensions of the circular steady described in the book are for a PM 3520B.
Lyle Jamieson
Lyle Jamieson
I suggest you use 4 wheels if you have the option. If and when you start doing heavy, larger items the extra wheel is a huge improvement over a 3 wheeler.
John Kaner
Ouch! Worked late last night and grooves cut for 3 arm variety...
I will remember this for the next one. After all, I have 5 more wheels...
