Wood Turners Bandsaw Blade questions
I bought a Highland Hardware Wood Turners blade. Its advertised as a 3/8" blade. Supposed to do a good job in wet blanks.
Mine appears to be a half inch blade. Which part of the blade measures 3/8" or or whatever? Is it the entire width of the blade including the teeth or the narrowest part of the band from the bottom of the gullets?
Anybody use the Wood Turners Blade? Like it? What width is yours.
Re: Wood Turners Bandsaw Blade questions
bob davis
i use a 3/8in. timberwolf blade from suffolk industries for more than 10 years. had bad luck with highland blades, poor quality... sounds like they sent you the wrong size.
Rob Wallace
Rob Wallace
Hi Barry:
I have been using Highland [Hardware] Woodworking's "Woodturners Blades" for many years and find them to be excellent for sawing green blanks, or even for most other rough work. When resawing, I switch over to their well-known Woodslicer blade, which also performs very well.
In fact, over the past 3 - 4 years we have put through a couple of group orders from Highland for our AAW chapter, where we bought a number of the woodturners blades together to save some costs, because a number of our more active members use them for roughing their blanks too. I always have a woodturner's blade on my "garage'" bandsaw which I only use for roughing blanks. I guess I have at WT blade on my "main" bandsaw down in the shop at least 60% or more of the time as well. I think they work fine for doing what they say they do for green blanks. I actually touch-up the teeth with a 5/32" diamond chainsaw sharpening bit in a Dremel tool when they begin to get dull, and the few times (maybe 4?) I have snapped a blade because of being too aggressive while cutting, I have brazed them back together and have gotten even more "mileage" out of them. I like these blades a lot!
The blade should measure 3/8" (ca. 10 mm) from the blade back to the tips of the teeth, and the spacing between the tips of the teeth is about 8.5 mm; it should also be quite apparent that the teeth have some set to them, which, along with the deep gullets, clear out much of the sawdust during the cuts. The backs are moderately flexible and have some 'give' when encountering knots or other "challenges" during the sawing process.
If your blade width is 1/2" from back to tooth tip, I think they must have sent you the wrong blade.
I hope this helps!
Rob
I went and checked the blade....
The bowl blank blade is advertised as a 3/8". The blade I got is a half inch from the tip of the teeth to the back of the blade. It also appears to the same width as the Wood Slicer blade they sent in the same package as a half inch blade.
I have sent them and E-mail but probably won't hear back until Monday at the earliest.
Rob Wallace
Re: I went and checked the blade....
Rob Wallace
If it was a new Woodslicer blade, the entire length of the blade would have been wrapped in paper (mostly orange paper I think) - you definitely would have noticed this!
It sounds like one of their 1/2" 'stock' blades was mis-located when it was inventoried, they pulled one from that location for your order, and no one checked that it was a Woodturners blade prior to shipping. Recently shipped Woodturners blades have had a white paper tag from their supplier stapled around the coiled blade; the tag has the blade length, thickness, and width stamped on it.
Customer service is pretty good at Highland - Owner is Chris Bagby, and his wife Sharon Bagby handles accounts and a good bit of the customer service inquiries. I am sure they will correct the error Barry - they've been excellent to work with in past years for me.
Good luck!
Rob
OOPS! My Bad! I owe Highland Hardware...
an apology.
We had the Wood Slicer blade on the saw and wanted to switch to the Wood Turners blade. I told my son to bring one and he grabbed the last regular 1/2" blade I had sitting on the shelf. He had put the blades away and I had not noticed the Highland ones had a tag on them. So, after someone mentioned the tag, I went and checked and I still have both Wood Turners blades sitting idly by.
So, I apologise the Highland Hardware and will E-mail said apology to them. I am looking forward to trying the blades.
