Threads again. Strengthening with acrylic.
Craig Daymon
Cutting thread in end grain is always going to create weaker threads than those in face grain (of the same kind of wood) since you are cutting the grain into stacks of tiny pieces. Threads in softer woods are frequently problematic.
So how to strengthen them. Many use cyanoacrylate, but that is brittle and is reported to not last over the years. (For any gluing purpose.)
A local turner has stabilized pen blanks by throwing them in a vacuum container in a bath of acrylic shavings dissolved in acetone and keeping them under a vacuum for...a couple days.
I don't have the equipment or desire to stabilize a blank large enough to turn a box, but I'm wondering if painting the area to be chased with the same acrylic and acetone solution would be an ideal way to strengthen threads. It's easy enough to make and can be brushed on with a disposable glue brush.
Thoughts? Comments?
Thanks,
Craig
P.S. Also I'm wondering how this solution might work as a very impenetrable finish. I think it is a bit gummy, so after cured you'd probably have to sand it smooth and polish it the same way you would finish a solid acrylic turning, but it might protect those wood colors that are affected by exposure to air.
