Chain maille is turned
steven antonucci
After surfing YouTube to learn how to do it, I surfed YouTube again to learn how to make the things you need to do it.
As it turns out, I tripped across a video of a rig that a guy had made with a drill and a bunch of wood and steel. It was functional, but it was some geeky kid in his parents basement. I've got skillz. (and a well equipped shop!)
As it turns out, winding the metal around a mandrel is exceptionally easy to do on a 1.5 HP Nova. I grabbed a piece of 3/8" steel and drilled a hole. Insert wire. Turn handwheel to get the first coil or two and lock everything together. Put on heavy leather gloves to hold the spool, and flip on the lathe. At 200RPM, it's very manageable. I suspect I could slip the belt down a notch or two with no issues.
I "turn" a 16" coil in about a minute. Each link is hand cut off with aviation snips afterward. My son was the one that got me started, so it's family time. One of the twin wants to be like his older brother (other one doesn't care) so we give him some links and pliers. My daughter claims all of the bracelets.
So, it's easy to combine family and turning and outside interests (at least in my mind
Steve
P.S. I'll think about the hook video. as it is, I am a hand short when I make them and there is already a fire burning...
