My First Wall Hanging
Jennifer Indy.USA
Well here's something entirely new for me. I've always wanted to try making a wall hanging so I did. This project was a ton of fun. It was interesting to work on a larger scale for a change and to see the impact that the usual designs I use can make on this scale compared to my usual 2-5" scale. For these pieces I used 12/4 poplar boards and ripped them to width and then glued the faces up with brown paper in between. I made three blanks, the longest being right at 48" and the shortest 38" and one in between. After clamps and drying I cleaned them up to somewhat square on the bandsaw. I turned the spindles and then split them apart so I got two sets of three pieces. The other three are waiting to be finished. This set was turned then burned and then dyed with Fiebings USMC Black leather dye. Art Liestman gave me the idea of using acrylic dowels to keep them from sitting directly onto the wall. Thank you Art! So I ordered 3ft of 1" acrylic dowel. I cut them into short pieces and turned a tenon to go into the piece and then made a jig to hold them to pass them over a keyhole bit on the router. I made keyholes on both ends so they could be flipped end to end. The design can go in either direction. They are finished with Spray Deft satin finish. I have to say these were by far the hardest thing we've ever had to take pictures of. The background, the lighting, the shadows. We tried lights in every position behind light fabrics and scrims. I think at one point there was a light clamped to every chair and perhaps on the dogs tail! It was a nightmare. So these are the best I have at this time. These were shot inside. We even took them outside on an overcast day and had trouble with that lighting too. Fun to make....not fun to take pictures of. Hopefully you can get a feel for what they actually look like. Comments welcome!
Jen
