Paduak and threads
Paduak and threads
Paduak and threads
Craig Daymon
I picked up a nice 3x3x12 chunk of paduak at Rockler today, out of which I plan to make a few boxes. I recently made a thread chaser out of a 3/8-16 bolt and want to try it out. I have some other woods, but I was wondering how well paduak would handle threads. Has anyone tried this before?
Thanks in advance,
Craig
P.S. Here's a pic of the thread chaser, along with the spoon I turned for my sister, which still needs work on the bowl. Not as happy with the spoon handle and I shouldn't have turned it off center to make the bowl deeper. It is much deeper than necessary, which means more carving.
Re: Paduak and threads
I doubt that Padauk will be suitable ....
JamieDonaldson
..for holding threads because its rather soft, unless you pre-treat the area to thread with thin CA glue.
Steven Antonucci
Or turn it face grain
steven antonucci
Some woods thread much better in face grain orientation than they do in end grain. Cherry is an example with this type of threader.
Steve
robo hippy
If you take very light cuts, and oil in between each cut, you might get away with it. Other than that, it will crumble. Box wood, Mountain Mahogany, Lignum, and maybe one or two others are great. PVC is supposed to be good, especially for practicing.
robo hippy
carl civitella
I would have never thought about such a solution for threading. I see you ground a flat on the bolt, but what is the best way to apply it to the piece ?. I have to try that, i gave up on the idea of threading, because of tool costs. This i will try. Carl
I have not tried chasing threads in Padauk. It's a little soft and would probably be difficult. Use wax before and during each pass and it may help. I am still new at hand chasing even though I've done quite a few boxes. I find the soft woods are quite difficult.
Mark StLeger is very good at chasing maple. I still have problems. It's obviously experience since Mark has been doing it much longer. When you chase threads in something like hard maple and then do the same thing with Boxwood it's like a huge difference. The boxwood is so easy.
Because soft woods can be difficult and that's what i mostly have I purchased the Baxter threader from Bestwoodtools. It will cut threads in very soft woods.
Another option is to cut rebates where you want the threads and fill that with epoxy. then turn away the wood and chase the threads in the epoxy. I will be doing that next week for a project.
The cut in half bolt works pretty well but I find the traditional shaped chasers work better. I wrote an article on how to make one that is in a past issue of Woodturning Design. I'd have to look it up to tell you which issue. They aren't hard to make it just takes patience. I've also made them by welding a bolt to a piece of steel so the threads were oriented the same as traditional chasers.
I meant to reply that PVC is excellent to practice on, however it's much easier to thread than softer woods so practice a lot.
Re: Paduak and threads *LINK*
Craig Daymon
Mike Darlow shows a ground bolt in his 3rd book. He covers threading quite extensively in that book, though he doesn't detail using a bolt specifically.
Also, Fred Holder wrote an article on using bolts for thread cutting in his More Woodturning magazine/e-zine. It was the March/April 2003 issue and may still be available.
He also shows a power threading rig you could build for about $80, based on pricing I've found. He uses a cross vise raised off the lathe bed with a plywood platform. A piece of threaded rod with the same threading as your headstock is used, about 12" long. 4 nuts (3 is possible) and a 60 degree dual angle cutter are needed as well. The threaded rod is held in the vise by clamping to 2 nuts on the rod. Your chuck is threaded onto the rod, backing up to a 3rd nut. A crank handle (which you could make yourself) is put on the tailstock end of the rod, backing up to a 4th nut. (Epoxying the handle onto the end of the rod would remove the need for a 4th nut.)
I'm presuming you have a drill chuck. The drill chuck is mounted in the headstock with the cutter in it. Your workpiece is mounted in the chuck. Align the cutter to where you want to cut your threads, turn on the lathe and start cranking the handle.
Enco has cross vise, Enco brand, currently on sale for $39.99. They have 1"-8 grade 2 plain steel finished hex nuts for $0.59 each. A 2 foot length of 1"-8 threaded rod is $9.11 and a three foot length is $12.68. The high speed steel cutter, model #367-7100, is $21.99 or a cobalt one, model #325-4039, is $37.98.
You could do away with the cross vise and build a mounting base for the system with scrap plywood. It just needs to move perpendicular to the lathe bed to align for the cuts. Assuming you have the scrap plywood and a drill chuck, this means a cost of less than $35. Should be a one day project.
Enco's Site
Craig Daymon
I guess I'll use the Paduak for some more traditional "Mike Stafford" style boxes. I do have one other new trick I haven't used yet that I could use with those.
I bought some 1/8"x1/8" cylindrical rare earth magnets from K & J Magnetics, Inc. and I have some 1/8" diameter steel rod. I'll embed a magnet in the lip of the base and a similar sized piece of steel rod in the lip of the lid, covering them over with a little glue and sawdust. That way it will hold a loose lid on and keep it aligned grain-wise. The magnets were $16.50 for 50, delivered ($11.50 + $5 shipping). They were the more powerful ones, grade N52. I like K & J, they seem to have good prices and there is lots of information on their site.
Probably should start another post for this, but has anyone done this and, if so, are there any considerations to take in?
Thanks again,
Craig
I may have my names wrong, it's too early in the morning, but Sharon Doughtie did a demo on box making at the AAW symposium. She just used 2 small rare earth magnets inbedded in holes and filled with sawdust. I really liked that idea but haven't tried it yet. It is a very good way to keep the lid aligned.
by the way a screw fit lid will not stay perfectly aligned all year. As the seasons change and the wood moves the top will screw on either more or less and won't align perfectly. If you do a good job aligning it when you cut it, it will be pretty darn close for most of the year. My experience has been that the lid can be as much as 1/4" off if the house climate changes very much.
Steven Antonucci
Or you can watch my video (I feel so slighted )
steven antonucci
Steve
Re: Or you can watch my video (I feel so slighted
carl civitella
All i can say, is thank you for the info. I think i can do that. I always thought there were high tooling costs to make threads, something i would not want to invest in for the occasional threaded box i would make. Thanks again.. Carl.
Carl, Take a look at Al Crandall's jig... *LINK*
Craig Daymon
...in the WoodCentral articles section. Al uses a router, so his lathe is not tied up, but it would be fairly easy to build his jig, basically what I was mentioning in my last post with the Enco link, and mounting the cutter in a drill chuck in the lathe. Although it is important to adjust the piece to be threaded perpendicular to the lathe bed, it isn't really necessary to use a threaded rod to adjust it as Al has done on his jig. Just as long as you can lock down the jig once it is adjusted.
I was thinking about the necessary parts today and one thing that I would use to assist in building the rig, and possibly in setting it up for use, would be a coupling nut to insure the headstock spindle and the main threaded rod of the jig are in alignment. Here are the Enco part numbers I wrote down for building such a jig for my JET mini.
1"-8 Coupling Nut (Optional) - Part #407-4982, $5.61
1"-8 Threaded Rod, 2 ft. long - Part #619-1524, $9.11
1"-8 Hex Nut (3 minimum) - Part #325-3209, $0.59 each
60 degree Double Angle HSS cutter - Part #367-7100, $21.99
Assuming you already have a drill chuck, you would also need some scrap plywood along with some bolts, washers and wing nuts to lock things in place once set up. I might consider using UHMW plastic for a runner in the dado(s) that I believe would be required to allow for the perpendicular adjustment. (I'd probably use 2 parallel dadoes with a slotted hole parallel and half-way between the 2 for the lock down bolt.)
I'm guessing that 12" of the threaded rod is all that is necessary, so you could split with someone on that part of the cost. A 3 foot section is also available for $12.68, part #240-0542.
Another consideration, instead the wing nuts, would be adjustable handles like those on the JET mini's tailstock and banjo. Woodcraft sells one for $3.99 each, or if you buy 4, $3.59 each. Part #129131.
This is helping me bash out how I would do it. Hope it helps you as well.
-Craig
Al Crandall's Threading Jig - WoodCentral Articles
