Drozda-esque Lidded Box
charlie belden
Been playing with the proportions of Cindy Drozda's "Onion Finial". Having drawn several - to scale - using the proportions I worked out from an example in her drozda_fiinals.pdf handout, finials must've been floating around in my head.
Around 2 AM, my Muse woke me up with an idea for a piece. Why do a lidded box and put a finial ON it - when - you can have a finial - with a box IN it?
The idea rattled around in my head and wouldn't go away. So I got up, got on my Mac Mini and opened up the Drozda Proportions spreadsheet. With all the proportions worked out as equations it was easy to derive the necessary height required for a 3" diameter "box" in the "bulb" of the "onion". Came out to be 15".
Opened up SketchUp and , using 15" as the height, constructed the profile from the spread sheet derived values for the control points, added the "top to bottom fit" details, spun the top and bottom profiles to create the two parts, then colored each - black outside, gold foil inside.
Here's the Sketch Up construction. The hollow in the base is for adding molten lead - to weight the "box" so it won't tip over
And here's the Finial Box, again from a screenshot of the SketchUp model.
Now all I need is to work our the Between Centers and Chucking sequence - and find a piece of dry wood that's 3 3/4" square and 16" tall.
A variation of Thinking Outside The Box - Thinking INSIDE The Finial.
