Way off topic
bill Crommett
Does anyone have a clue as to how I can get the baked on charcoal off the bottom of the turkey roaster ?
Way off topic
bill Crommett
Re: Way off topic
Dennis in Southern Oregon
If the roaster is not aluminum, you might try brush-on oven cleaner. Just follow the directions.
Dennis
Re: Way off topic
Stuart Johnson
Heat it as hot as you can get it and then hit it with cold water. Call any that doesn't pop off patina and move on to the next chore.
I'm with Stuart.
Make more gravy!
JamieDonaldson
Soak in Baking Soda or Ammonia
Jack Savona
If you do ammonia in the oven overnight, it should clean the oven, too. Just wipe off the gunk in the oven.
leave it out for the racoons
Re: Way off topic
Mike Stafford
If it is not aluminum I have found that you can coat it with Easy Off oven cleaner and leave it outside and let the dew do the job for you. Again the pan cannot be aluminum!!!!
If you just let the pan/grill rack or whatever sit overnight and let the Easy Off do its job you can just rinse it away with a hose and finish it off in the sink.
Once again: Do not use Easy Off on aluminum pans!!!!
Re: Way off topic
David DeCristoforo
What... you don't have chisels?
Re: Way off topic
bill Crommett
1) Chisels are hard work.
2) I have some saw blade cleaner that I no longer need, so I will try that.
3) Hot pan hit with cold water. Sounds like how we used to crack up field boulders when we were too close to a building to use dynamite
4) Leaving it for the Racoons is unacceptable. Coons around here are attracted to live traps only, waiting for the 8 cylinder lullaby.
Thanks fellows. It only goes to prove that wood turners have many other talents. And some are smart-asses.
Re: Way off topic
Emmett Manley, Lakeland, TN
I use a rotary wire brush on an electric drill to remove burnt stuff from pans and skillets, inside and outside.
I have had luck in the past
Barbara Gill
I use hand cleaner. I guess the same stuff that cleans grease, etc. off your hands will dissolve the burned food. I apply the cleaner to a dry pan, allow to sit for several hours and then scrub. If that doesn't get it all, allow the pan to dry and repeat until you are happy.
Re: Way off topic
bill Crommett
The roaster is now sitting out on my welding bench with a bunch of foamed sawblade cleaner covering the bottom. I will check it tomorrow.
Re: Way off topic
robo hippy
Well, 80 grit works.
Problem with leaving it for the racoons, they will run off with the pan.
robo hippy
