Re: OT: Firepits
Pete in Holland MI
Steve -
I built my own fire pit from an old electrical panel from a machine. Current one is 8" deep x 24" x 30". Weld some angle iron on the corners to raise the bottom about 8" off the ground, and some big flat washers to keep it from settling into the lawn. Remove the back panel from the inside of the panel and weld it to the outside bottom of the panel, with some 2" spacers for it to function as a heat shield. I put a pair of steel wheels on it, along with a short handle to pull it around. The door hinge pin is removed and the door serves as a lid to keep the rain out.
These last me 3-4 years.
We have campfires frequently in it. It's portability allows it to be in the front, back, or neighbor's yard. The heat shield protects the grass. It is also the place where I burn up my scrap lumber and turning noodles thru the winter.
In the front yard, it serves as a draw to the neighbors on a Friday night to come over for a beer (BYOB) and just chat for the night. Have had some mighty fires in it over the years, and I encourage all of you to try one out. It does wonders keeping your neighborhood closer together !
Pete
