Drozda Finial Analyzed (numercaily)
charlie belden
Probably because of all my training in engineering that sets me looking for Underlying Principles when it comes to design - and other things. I look for reasons why one design works looks right while another very similar design doesn't.
Going through the log of the chat with Cindy Drozda, and the "drozda_finials.pdf" file that the chat linked to, got me analyzing the illustrated example in the pdf file. Copied the illustration into a primitive CAD program that would let me scale values, and used a spreadsheet to play with the scaled values - and relationships between critical dimensions of a Drozda Finial. Not surprising, I found FOURTEEN critical dimensions, and they all can be derived from the finials HEIGHT.
While the Golden Ratio (1:1.618) plays a major role, "3rds", "4ths" and "5ths" are used for the minor details. The "3rds" and "5ths" were expected. The "4ths" was a bit of a surprise.
I've done an Excel spread sheet that lets me specify a finial height and calculates each of the critical dimensions. Found that working in millimeters was easier than working with fractional or decimal inches, but the spread sheet doesn't care what units you start with.
Here's the illustration and the formulas for calculating each critical dimension. If there's interest in the spread sheet, I can put it on my WWing site and post a link to it.
Re: Drozda Finial Analyzed (numercaily)
Barbara
Charlie,
You are amazing!!!!
Bill Noce in Northeast Ohio
Unbelievable Charlie....
What a special talent!  Thank You, Charlie
Peter Hyde
Mmmmm. How come L4 has 2 different values?
Joe Donohue
Charlie, I for one would appreciate a link to the excel file.
Thanks
Joe Donohue
David Walser
What's really amazing is that Drozda does all those calculations in her head!
gary clarke
It would be interesting to measure several of her finials and see if they all fit the equations. I am not an engineer or math major so I leave it to someone more qualified.
Carol Reed, Pahrump, NV
I think Cindy would be thoroughly amused!
REVISED Drozda Finial Analyzed (numercaily)
charlie belden
Peter Hyde asked "Mmmmm. How come L4 has 2 different values? "
Answer: Variables numbering scheme error.
Another example of the benefits of Peer Review
Here's the REVISED (read "corrected") illustration with equations. Note that the number under each varialble is its Scaled Off The Original Example length, in millimeters (mm), rounded to the nearest whole millimeter.
There are 25.4 mm per inch so 1 mm = 0.039". As a reference, 1/32" = 0.03125"
Here's a comparison of the calculated values (calc'd) vs scaled (from the original drawing). As you can see, the calc'd values, with the exception of D1, all are within +/1 one millimeter of the scaled values - for a 7 1/8" tall finial. The shorter the finial the smaller the differences become.
Note that the intent of all this stuff is to get you CLOSE to the proportions Cindy has developed for her finials.
charlie belden
That's the difference between an engineer and an artist. The artist can see if something "looks right", usually based on a LOT of experience. The engineer can only work out the proportions of something the artist provides. The math is easy. The refined sense of what looks right ain't.
Cindy Drozda has, with a lot of trial and error and a lot of thought, developed a refined sense of what "looks right" and what doesn't. And that's something she stressed in her Chat Session - doing ten or more versions of an idea allows the idea to be refined. Having done probably several hundred of her elegant finials, she has refined them to the Nth degree.
charlie belden
No good deed goes unpunished.
I've started collecting images of different Drozda finials. Finding good profile shots may take some time. I'm betting that the the Golden Ratio will be major factor in the proportions, with 3rds, 4ths and 5ths playing a role in the proportions if the details. The Search For Secrets will use the same approach as used for this first cut at discovering them.
charlie belden
If all this results in just a smile of amusement - it's worth the effort, Anything beyond that is gravy.
If nothing else, I hope this stuff gets a few people to start planning things a bit more rather than chucking up a piece of wood and see where things go as the chips fly. I've been Wingin' It most of the time. But for certain pieces - like lidded vessels with a finial, I'll be doing a bit more planning.
Me, too, Charlie. Thanks.
charlie belden
Cindy is the one who worked out the elegant proportions of her finials and I'm certain a lot of time and effort went into developing the fundamentals and then refining the form to the n'th degree.
All I did was find the critical points and work out their numeric relationships to the height of the finial. And I suspect that the finial height is determined by its relationship to the piece it will crown, probably using the Golden Ratio (1:1.61803398874989484820 - though 1: 1.618 is close enough) - the vessel height probably the "1.618" and the finial being "1" - or the other way round.
Interesting little side note
1/1.618 = 0.618
which happens to be what you get when you subtract 1 from 1.618 (1.618 - 1 = 0.618)
Real vs Ideal
charlie belden
I found a photo of one of Cindy's pieces with a finial and compared that Actual finial with the Ideal finial in her drozda_finials.pdf handout. With a little playing in PhotoShop I got them to the same size, without changing the proportions of the original. Here's a Side By Side comparison and the Ideal overlayed on the Real.
Now the Real finial is from a piece with a "long axis horizontal" hollow form(wider than it is tall) so she may have intentionally "lowered the center of gravity" of the finial and thickened things up a bt to go with the "low center of gravity" of the hollow form. The piece has a more "grounded" look than her taller than wide, more "lighter" pieces.
It would seem that, starting with an "ideal", proportions can be adapted to go with the hollow form, yet still keep the Drozda look. THAT is where the Artist comes in - adapting to the context - and there ain't no equations that hold fast and true for all cases.
So what do you come away from all this with?
Re: Real vs Ideal
Fascinating!
