Back At The Lathe - Finally!!!!
Dick Wilson
I have been out of the shop for a month with chest crud. The dust really put me down. And just what lump of wood did I select to restart my turning fun? Eucalyptus Red Gum Burl!!!!!!!!!!!!! A really smart choice. I have turned a lot of dry Aromatic Red Cedar and always thought it is the nastiest wood on the planet. WRONGGGGGGGG!!!! This stuff is by far the nastiest. It is harder than a rock and dense. The "shavings" come off the tool as either fine red dust or granules the size of coffee grounds. A dust mask and vacuum hood are mandatory!
I bought this piece when I was at the Ohio Valley symposium and because have never turned it I asked Richard Raffan about it. He said that if I have never turned it before that he strongly recommended that I not try to turn it thin. Sooo, I turned the outside profile I wanted and before hollowing it I duct taped the entire outside. The entire piece is nothing but crevasses. Safety first.....I didn't want a spinning hand gernade while hollowing. Yup, I am cowardly :D
Anyway, the piece is approx 8" tall x 6" wide with a 1/2" wall thickness. Finished with Deft rattle can lacquer. Buffing to come. C & C welcome as always. Sorry for the lousy pic.
Re: Back At The Lathe - Finally!!!!
I dunno Dick,
Mike Foster
I just got done working a piece of desert Ironwood and currently working with some Macssar ebony. Both of these cut similar to your red gum. Fine powdery black dust (no shavings) that gets everywhere and turns everything black. I use my dust collector and the Airstream when working either. To top it off, both of them have a nasty smell. I only turn them because they are both outstanding once finished.
Your vessel looks great. I like the shape, and the texture of the wood is what really makes it special. I would say it was worth the trouble.
Steven Antonucci
Don't drop it on your foot!
steven antonucci
It's a great shape. I started to think "wow, 1/2 inch thick" but then I rethought it through...
If you turned it much thinner, it would have opened up all of the gum pockets. The look of the piece and start being able to see through it, it completely changes the entire piece. Neither is better or worse, just different.
You also commit to sanding the inside clean when you can see it, or at least having to do something. By leaving it thicker, you can get away without...
Good job!
Steve
Brad Vietje
No Coward -- A Smart Man!
Brad Vietje
Atta Go, Dick!
Congrats at getting back to the lathe and expelling the "chest crud". That is wicked cool looking wood, and I think leaving it thick and heavy (and intact) is a good call. I may try some one day, so it's good to know in advance that it can be not-so-much-fun to turn.
When you turn these thinner and the gum pockets show through to the interior you can sand it, or even try painting the interior black for a more mysterious look.
Looks really nice from here -- if you need to get rid of another chunk of this miserable wood, just let me know!
Safe spinning,
Brad Vietje
Newbury, VT
