3520B quill replaced
Rich Egan
Last week or so there was a thread here about the quill and lead screw on a 3520, and how heavy boring could damage the threads. A Powermatic technician suggested to me the quill and screw should be hardened if I intended to do a lot of drilling. My problem was unrelated to that, in that my quill would bind inside the tailstock with or without the lead screw. I replaced my quill and screw yesterday, and find my quill now operates like new, or maybe better than new. I'm thinking of bringing my old quill in to a machine shop to see if it is slightly bent. I don't think it would take much to cause some binding, as the tolerances are pretty tight.
Re: 3520B quill replaced
Peter Hyde
I had this problem almost from scratch. What I think is happening is the cast iron of the tail stock is distorting slightly as it ages. There is a reduction inside the casting towards the rear that provides a bearing surface. This is where mine was sticking. I reamed it out just enough to get the quill moving nicely and a month later had to do it again. No problems since.
Jason Silva
My tail stock suddenly became impossible to turn. I took it apart, cleaned and greased it, replaced the keeper plate (Nova DVR XP) and it still bound up in the tail stock. This drove me crazy! After months of suffering with the issue and not knowing what was wrong, i took it apart one last time, cleaned everything up and set the quill down on my table saw. I was planning on ording an entire new tail stock. I looked over at my quill that had begun to roll on the cast iron table saw top and low and behold...it was bent. It wobbled...ever so slightly...but that was all it took. Ordered a new quill for $45 and its good as new. The quill is one solid piece of metal...cant imagine how i bent it but i did.
Rich Egan
Jason - That sounds like what has happened to mine, but I have not checked it yet. The tablesaw top might work. I'll have to try that.
