Scored some Beech
Scored some Beech
Scored some Beech
Jorge
Today brought me some chunks of beech, the biggest 19" across the smallest 14", a 15" chunk has a 9" hearth wood, and a broad band of sapwood, all the chunks share that broad band of sapwood.
Never turned beech before, how does it behave? It is wet, just cut a couple days ago.
Thanks for any info.
Jorge
Re: Scored some Beech
Want More?
I've got a 18"er down in my front yard, courtesy of Irene. :\
Turn wet to completion and see what develops. Wait 'til dry or try to double turn, get out the stone tools; works like concrete.
Crotch can be interesting, but most often pretty plain-jane stuff that I've had
Steven Antonucci
I knew I heard cracking from the north
steven antonucci
beech turns beautifully and then cracks. I love it, but I haven't had a tun of success in finishing it. it moves so much, it tears itself apart.
I've seen cracks as wide as an inch. If you leave it outside, it will spalt aggressively.
Good luck. Make a cowboy hat.
Steve
Re: Want More?
Jorge
Hi Mark!
Long time...
I guess I will try both ways, the large sapwood made me suspicious.
I don't know if I want more until I turn this...
Gracias!
Re: I knew I heard cracking from the north
Jorge
Steve, I've been curios about beech since I saw Glen Lucas pictures, he uses it a lot, so I decide to try it. It has a wind shake right at the pith and I will loose a couple inches to get rid of it but other than that it looks healthy, with all that sapwood i can understand about moving a lot.
I know what I'll do tomorrow..
thank you!
Steven Antonucci
wrap it in a wet towel and plastic bag overnight
steven antonucci
it'll be split if you don't.
S
OK Thanks!
Brad Vietje
Brad Vietje
Jorge,
I really like Beech (have only used Am. Beech with the exception of a few chunks of spalted English Beech I bought years ago, in Providence), but you have to treat it with great respect. Like others say, it moves a LOT, so if you twice turn, treat it like Apple (or like Madrone for westerners) -- it moves a lot, and rather quickly. I'd spray it with water to keep it damp while rough turning anything large.
One of my favorite bowls is from slightly spalted Am. Beech, which would have been much tougher if the spalting had progressed a little further. I've had good success by waxing rough-outs with paste wax allover while spinning on the lathe.
I like Mark's idea of doing some thin-wall artistic turnings, and letting Mother Nature have her say in the final shape.
-- OR --
Split it into riven pieces for spindle projects, pepper mills, finials and the like. A year or two of air drying, and you'll have a nice stash of spindle wood. I split up a few billets about 5 years ago into little 1" squares, and use them for ornament finials, and other small stuff. Takes detail almost as well as any species out there. A lot of New England furniture was made from Beech legs and stretchers, so maybe those old bodgers knew a thing or two about their materials...
Safe spinning,
Brad Vietje
Newbury, VT
Jorge
Hi Brad,
I will have water on hand and squirt it while turning, Maybe I will give it a coat of Anchorseal as soon as the exterior is done.
Good idea, I like it, the tree was not round, one half managed to be close to symmetric the other half are irregular so I was thinking that, rive those and let them dry to use down the road.
Yes the old timers knew a thing or two about the woods around us, beech was also used almost exclusively for the bodies of hand planes, so after the initial moving it most become very stable, I have quite a number of old planes all made of beech. I also have a thick A2 iron and just maybe now I will get to make a smoothing plane with it.
Thank you!
