What are you suggestions for keeping the rich purple cflour of juniper or aromatic cedar ( whatever you wish to call it). I have a small bit of it and while the reddish brown it becomes is gorgeous, the purple is breathetaking. I am thinking Krylon's UV resistant-clear.
Put it into a hermetically sealed container with no light. Seriously, it will eventually turn brown . You can delay it by keeping it out of daylight and using UV protectors on it, but it will change.
Some years ago I did some experimenting with finishing juniper (or what others might call "cedar"). The bright red color eventually does diminish and shifts to a reddish brown color with age.
I found that blonde shellac and lacquer retain the bright red color best, at least in the short term. Polyurethanes (both water-based and 'solvent'-based) might provide some additional UV protection, however these may also effect the final color a bit more than shellac or lacquer. "Varnishes" also give a chromatic shift as well, given they often impart an amber cast to everything they are used on. I also have tried boiled linseed oil, Watco, tung and walnut oils and can tell you that all of these severely darken the juniper's color, and in my opinion, "muddy" the surface significantly. I would not advise using oil finishes on juniper, unless you're ready to accept a much darker color than the unsanded color. Use of waxes directly on unfinished (e.g. sanded only) wood produced results similar to oil finishes, which is not surprising.
For me, this has become a moot point, since I now rarely, if ever, turn juniper - mostly due to its irritating volatile terpenes and the disagreeable effects the dust has with my respiratory system, even when using filtered air face shields. To me its just not worth this hassle when there are so many other beautiful woods available which don't leave my shop smelling like the inside of a hamster cage.
The brown tones that result are quite nice Steve. Minwax have a Teak Oil now that has UV Protectants in it. The Minwax rep gave me a can at last year's Hamilton Wood Show, but I have never got around to using it. Expect that it behaves like a Danish Oil. Try a natural edge end grain vase with it. You get some realy cool rims with the usually irregular shape of the wood.
