Belt life
Belt life
Steven Antonucci
Belt life
steven antonucci
Anyone here know what the average lathe belt life is? I have one making an awful racket when I turn my lathe on... It doesn't look obviously bad (no fraying)...
Steve
Re: Belt life
Re: Belt life
Stuart Johnson
My Nova3k first belt went after about 6 months. The replacement has lasted 9 years. The spare is hidden do deep it will probably last at least 100.
Re: Belt life
Re: Belt life
dickhines
I still the belt that came on my PM 3520 that came on it in 2002
Re: Belt life
Re: Belt life
rjstavran
The power twist segmented belts have worked very well for me. In addition to smoother and quieter operation you don't need to dismantle pulleys to change/replace belts. The belts I have replaced with power twist belts show little sign of wear if any. I can't explain how a segmented bumpy belt can operate better than the typical v-belt.
Re: Belt life
Re: Belt life
Darryl
Steve on my Nova 3000 the first one less than a year the replacement over 3. Look at the inside of the belt. They tend to crack in small segment underneath and that gives the strange noise. The top looks great but the underneath might be crazed or showing small cracks. Also might check the wheel if it is a bit loose it will cause noise as well.
Re: Belt life
Re: Belt life
mjonesrdg
A couple of squirts of belt dressing helped my Nova belts quit squealing and, according to the manufacturer's claim, extended the life too.
Re: Belt life
Re: Belt life
Steve I have yet to wear a belt out on any of my lathes and I used them all a lot. The only one I've replaced was my Carbo-tec and that was owned by a professional turner who used it daily for 2 years. The bearings were bad and the belt was worn but not brocken. I had to replace the bearings so I replaced the belt.
Re: Belt life
Harry Robinette
Re: Belt life
harry robinette
My General is a 1999 and no belt changes yet.
Re: Belt life
Re: Belt life
Steve Mushinski
Might not be the belt Steve - could be the bearings are starting to loosen up. If you have a stethoscope (shop type one or a screw driver to your ear) turn the spindle without the belt and listen for noise.
Also check the belt for an indention, if you started the lathe with the head stock lock on it will mark the belt and you will get the thump a thump noise until the speed over comes it.
Re: Belt life
Re: Belt life
Doug Turner
I have a Woodfast circa 1981 with the original belt and it get used a lot.
Re: Belt life
Steven Antonucci
Frickin' gremlins!
steven antonucci
I wanted to pull the belt off to get it to better light, but I have a handwheel on my Nova, and I would have had to take it off too. I am lazy, so I decided to just invert the belt to inspect the grooves more closely.
Of course, there was nothing in them, so I reinstalled the belt and the noise was gone. Go figure.
Thanks for the advice. 10 years on the belt, with who knows how many hours... why can't everything be built like a lathe?!
Steve
Re: Belt life
Re: Belt life
Jorge
Steve, my Nova 3000 went through a number of belts in the first year, until I got the pulley alignment just so and used two worm screws to tighten it, it still is working happily ever since for 5 years.
