Feel pain must be still Alive
dgelnett
Had one of those moments that when the bowl disintegrated and fly around the room I just stood still and started counting body parts waiting for pain. One of the bowl parts hit the back of my left hand finger which felt a lot like when the teacher hit the back of your hand with a ruler (that was a long time ago).
I had turned the upper half of the bowl to about a quarter inch thick with the lower part of the bowl still thicker. I was working my way down the bowl to obtain a uniform thickness. I noticed about 2 inches down from the top some tearing and went back and made some fine cuts to fix the tearing. Worked great but when I felt it noticed I now had a ridge about an inch down and needed to even it out. That’s when the problem starts, should never back up toward the top when a lower portion of the bowl is thinner but was not thinking of that at the moment but to fix the ridge.
You know the rest,, if your new and don’t this is what happens; with thin wood below and touching the thicker wood above with a tool can cause the wood to flex back and forth which can then cause a catch, the wood breaks at the thinner point of the bowl and parts just fly all over the place. This all happens in a split second.
Remember the old Batman series with all the words they put on the screen POW.
Re: Feel pain must be still Alive
What tool and type of cut ...?
Doc Green
Just curious . . . what tool and type of cut were you using when you went back?
Thanks, ~Doc
Glad your OK. I use a different cut when I have to go back over an area on a thin bowl. I rotate the flute to the right and cut with the tip or slightly above the tip. I try to put as little pressure on the bevel as I can. That has worked most of the time but I believe I posted about 7 months or so ago that I had a thin bowl blow up and cut my left little finger. I was going back to clean up some chatter marks and was using my left hand on the outside of the bowl to reduce tool chatter. worked many times before but not this time.
Re: What tool and type of cut ...?
dgelnett
The cut was a shear cut with a bowl gauge turned on end. I thought I had plenty of wood since it was just under a quarter of an inch but just as I aproached the wood I noticed a slight vibration and was thinking that the wood was starting to go out of round when the bowl just disapeared from my view.
Dick Coers
Wood species and moisture content makes a big difference too. Course grained, or dry woods don't like those touch-up cuts as much. I always go to the grinder and diamond hone before taking those type of cuts. John is right, no tool pressure at all, and a light grip on the handle. When I loosen up my grip, I automatically make a better cut. Glad the shrapnel didn't get you!
Dick Wilson
One of life's turning lessons. Not that I have ever done that :\ :\ :D >( . Next time: if the outside of the bowl at the rim is smooth you might try putting your fingers on the outside of the bowl as you are working inside. It will give you support AND dampen the vibration I suspect you created. Once the wall starts moving in and out all kinds of nasty things can happen. Time to grab another lump of wood.
you can always try a bowl steady  *LINK*
http://www.woodturnerruss.com/BowlSteady.html
