Russian Olive, how-to
Steve Kubien
Steve Kubien
Hey folks,
I got myself a couple of fresh pieces of Russian olive. I've never worked it before. Anything special I need to be aware of? Am I ok to twice-turn it or is green the way to go? I am planning to make some cross-grain bowls or perhaps a couple of mills.
Thanks for your help!
Steve
Re: Russian Olive, how-to
John Veerkamp
It will check as you look at it. Get the pith out immediately and seal the ends. You need really sharp tools to work it successfully. It can range from bland to beautiful.
Good luck.
Jeff Ferguson
Russian Olive is a nice wood to turn. It smells like burnt popcorn when turned dry. It has very dense and very soft grain differences. Be careful sanding otherwise all the softer grain will sand away leaving a very wavy surface. I am not sure it would be a good choice for peppermills given the grain issues.
Good Luck
Dick Coers
It's the only wood I have worked in 40 years that made me instantly sneeze.
Rob Wallace
Rob Wallace
Steve:
I turn a lot of Russian olive (Eleagnus angustifolia), and the comments about the differences in density of the earlywood-latewood are correct - you have to make sure your sanding is done without wearing away too much early wood, or you will get a 'rippled' effect.
While turning the wood (wet or dry) you should be aware that Russian Olive is particularly susceptible to ring shake, and a seemingly solid blank can be cracked within. Be careful while turning and stop frequently to check for cracks (and not just radial/ray cracks, but "shake" cracks too). I have had beautiful pieces come off the lathe in Russian olive, and others that seemed to self-destruct while still on the lathe due to incipient cracks already in the wood.
Good luck & turn safely!
Rob
Dale Jablonski
dale jablonski
One thing I've also found is it tends to go oval really quickly whether wet or dry. I did dimension some and made a segmented piece that did not go oval. It is a hard wood and I like to turn it when I can get it.
Steve Kubien
Thanks everyone
Steve Kubien
I appreciate all of your information. I will chainsaw it tomorrow and see what happens.
Cheers.
